Old 04-04-2016, 15:47   #1 (permalink)
GSM KPK's Avatar
Member: 2166444
Thanks Meter: 298
Plz Help Me infinity team
Start at : [4/4/2016 / 3:58:38 PM]
Operation : Check / Read Info [ v1.44 ]
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : 00EC00BC00000055005400EC00BC0000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x008C , [SAMSUNG] KA100O015B_BJTT
[NAND] : FLASH_DIE : 00EC 00BC 0000 0055 0054 00EC 00BC
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2
DEV RID : F3146F043BE9E7ECD0872B6ECA5A9885
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
flash file reda done ---and write thsi file-Flash-Tool hang and lago
samsung-s7582-
MT6572_NAND_samsung__GT-I8262__GT-I8262__4.2.2__ALPS.JB3.MP.V1
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : samsung
Device Model : GT-I8262
Device CPU : MT6572
Device IntName : GT-I8262
Device Version : 4.2.2
Device Compile : 10/23/2015 8:16:32 AM
Device Project : ALPS.JB3.MP.V1
Device ExtInfo : GT-I8262
Old 04-04-2016, 17:17   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Could you please explain what is the problem with your phone ?
Old 04-04-2016, 17:46   #3 (permalink)
GSM KPK's Avatar
Member: 2166444
Thanks Meter: 298
-mobile pattern lock problem
pattern lock -read error
full read file cm2 and flash -SP_Flash_Tool
mobile hang and lago
mobile samsunge gt-s7582
Start at : [4/4/2016 / 3:59:50 PM]
Operation : Read Flash [ v1.44 ]
Power Off Phone , re-connect battery , Insert USB cable!
Wait for phone...
Phone found! [ 20 ]
Sync...
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
[Read Ok] : preloader_mbk72_wet_lca.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : usrdata.img
[ScatCFG] : MT6572 / V1.1.1 / mbk72_wet_lca / NAND
FW Size : 338 MiB
Brand : samsung
ProdName : GT-I8262
ProdModel : GT-I8262
Device : GT-I8262
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1
Android Info saved
Scatter saved to : C:\Documents and Settings\gsm-mobile\Desktop\New Folder\MT6572_NAND_samsung__GT-I8262__GT-I8262__4.2.2__ALPS.JB3.MP.V1
Old 04-06-2016, 14:22   #4 (permalink)
shahabuddin's Avatar
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
may b this can help u
MT6572_NAND_samsung__GT-I8262__GT-I8262__4.2.2__ALPS.JB3.MP.V1 By Tabrez - Download - 4shared - Tabrez Ali
The Following User Says Thank You to shahabuddin For This Useful Post:
Old 04-06-2016, 16:55   #5 (permalink)
GSM KPK's Avatar
Member: 2166444
Thanks Meter: 298
THIS FILE id
[NAND] : FLASH_VEN : 0x0095 , [SAMSUNG] K9K8G16U0K
[NAND] : FLASH_DIE : 00EC 00BC 0000 006A 0056 00EC 00BC
Old 04-06-2016, 17:04   #6 (permalink)
Registered User
Member: 2530239
Thanks Meter: 14
Use 1.43 cm2 write ini prealoder write full buckup post result bro
Old 04-06-2016, 17:20   #7 (permalink)
GSM KPK's Avatar
Member: 2166444
Thanks Meter: 298
allredy chake this options sam problem
mobile on lcd blue
Old 04-06-2016, 17:34   #8 (permalink)
GSM KPK's Avatar
Member: 2166444
Thanks Meter: 298
Plz infinity team
add this options
mobile info FlashIC id show-
this file FlashIC id
-NAND] : FLASH_VEN : 0x0095 , [SAMSUNG] K9K8G16U0K
file sam id FlashIC id
change
plzzzzzzzzzzzzzz
add
full info read file show FlashIC id and all mobile allred this 2 file write cm2 no errors writen
Old 04-06-2016, 18:34   #9 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Options for what? If that FlashIC's managed for 128k and 256k IC's - it ok, mobile will die after wrong one.
Old 04-06-2016, 19:23   #10 (permalink)
solusi hp's Avatar
Member: 2162000
Sonork: 100.1670061
Thanks Meter: 205
nand flash again. different lcd firmware make only blue screen. only correct firmware can revive this phone use sp flash tool.
What i like from CM2 is ALWAYS GIVE WARNING ALL PROCESS.
SO IF YOU GET SOME ERROR LOG FROM CM2 DONT TRY WITH OTHER TOOL OR SP FLASH TOOL IF YOU DONT HAVE GOOD FIRMWARE.
Old 04-07-2016, 11:14   #11 (permalink)
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
@gsmkpk when i get free time i will upload system.img file for u
Old 04-07-2016, 13:33   #12 (permalink)
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
backup ur phone safe ur system.img file another place
and copy this system file in backup folder from link
https://www.4shared.com/file/eWj1otXvba/system.html
post result
Page generated in 0.29761 seconds with 9 queries
