04-03-2017, 09:51 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Lake Mary (Orlando)
Member: 1016569 Status: Offline Thanks Meter: 229 | LAva A97 FRP lock solution Its Lava A97 with FRP lock i tried all of ways Card found: S/N : C1******* , v0135 Chinese Miracle II [SPD module] v 1.24 Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Init Ok , reset settings ... Format Ok! Done Elapsed: 00:00:20 BUT FRP same AS before not resseting while CM2 showing FORMAT OK Reconnect Power/Cable! Tried to choose 9800 section cpu with Ltdr mode or without , but it showing ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! |
04-03-2017, 10:31 | #2 (permalink) | |
No Life Poster Join Date: Jul 2010 Location: chennai, india
Member: 1354113 Status: Offline Thanks Meter: 669 | Quote:
04-03-2017, 10:35 | #3 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
plz find Correct boot key,, In SVC mode Frp will not Remove,,, press vol+ and Connect | |
08-21-2017, 05:55 | #4 (permalink) |
No Life Poster Join Date: Mar 2015 Location: kapurthala punjab
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | Card found: S/N : AD4A22C5 , v0136 Chinese Miracle II [SPD module] v 1.24 Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Open Port Failed! Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Open Port Failed! Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001227F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
