Old 10-16-2008, 01:31   #1 (permalink)
Medusin's Avatar
Member: 400280
Thanks Meter: 63
Iphone chinese MT6226 signal low
Hi Friends I have 1 pcs IPHONE CHINESE CPU: MT6226 AND I LIVE IN COLUMBIA (850/1900MHZ) AND I NEED SOLUTION.....
I don't know if this phone have frequency 850/1900.... but I read information and backup for send us.....
InfinityTeam Can you help me???
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:C341:449C
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:2AEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\id.3DF4EB87.[MTK6226_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_40_ F1.BIN_B874FD0F].rpl
New firmware detected:
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 3DF4EB87
identification#1 protocol ver: 05
ver. sw1: MTK6226_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_40_ F1.BIN
ver. sw2: MAUI.06A.W06.40.F1, F0028B47
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\system_log_3DF4EB87_MTK6226_06A_PCB01_GPRS_MT622 6_S01.MAUI_06A_W06_40_F1.BIN_B874FD0F_20081015-191438.B0X.bin
Finished, time used: 177 sec
Remove/Install battery now !
log read BACKUP FLASH...:
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
device-id: 3DF4EB87
ffs chip: 00
reading: flash[MTK6226_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_40_ F1.BIN]...
file saved: C:\Documents and Settings\Administrador\Escritorio\flash[MTK6226_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_40_ F1.BIN]_20081015-192634.B0M.bin
file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\system_log_3DF4EB87_MTK6226_06A_PCB01_GPRS_MT622 6_S01.MAUI_06A_W06_40_F1.BIN_B874FD0F_20081015-192648.B0X.bin
Finished, time used: 637 sec
Best Regards.
Medusin
PD. sorry the thread title is MT6226 chip
Old 10-16-2008, 17:12   #2 (permalink)
Medusin's Avatar
Member: 400280
Thanks Meter: 63
mmmm not reply????? .....
Old 10-17-2008, 17:04   #3 (permalink)
Member: 148515
Thanks Meter: 14,623
hello!
unfortunately we dont have methods to select frequencies
Old 10-17-2008, 17:57   #4 (permalink)
ktienda's Avatar
Member: 309769
Thanks Meter: 36
hello!
but the problem is that in COLOMBIA exist other chinese iphone with full signal and other with no service(low signal)
soft version can be ?????
or only exist one version standar for all pcs ????
Old 10-17-2008, 18:29   #5 (permalink)
Member: 148515
hello!
i may be wrong, but per my knowlage they have different hardware (RF part)
Old 10-18-2008, 22:10   #6 (permalink)
Medusin's Avatar
Member: 400280
Thanks Meter: 63
hello!
mmm... but.. is very bad the problem because the phone (chinese iphone) get network but after X seconds the signal appear VERY LOW... in all sites from my country.....
I think that if the phone is flashed with FW (850/1900) example (firmware motorolas p2k with band 850/1900 or 900/1800)
Old 10-19-2008, 12:30   #7 (permalink)
Member: 148515
hello!
i can only advice to find same, but good working phones and compare firmware versions.
if they will match, you can try to clone working firmware (it will be with eeprom) to not_working phone
Old 01-02-2009, 03:58   #8 (permalink)
samusprime's Avatar
Member: 189984
Thanks Meter: 111
Hello..
Maybe i have the same problem too, its possible damaged the power amplifier, or RF part different???
Old 01-02-2009, 12:52   #9 (permalink)
Member: 148515
hello!
hard to say, this is different from model to model
Chinese MT6225 auto power on aliarjun Infinity-Box 1 04-17-2009 23:10
Nokia 1112B Signals Low asadnow2k Nokia Hardware & Hardware Repair 2 08-03-2008 08:44
7210 signal low ahspao Nokia Digital Core Technology 4 ( DCT-4 ) 0 06-14-2004 08:06
3310 signal low after change PA and Antenna switch Black-Axe Nokia Hardware & Hardware Repair 5 10-15-2002 14:35
Nokia 3310 Auto Off When Signal Low Williamcwy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 02-20-2002 02:08
Page generated in 0.33968 seconds with 8 queries
