08-27-2008, 08:50 | #4 (permalink) |
No Life Poster Join Date: Mar 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 52
Member: 59732 Status: Offline Thanks Meter: 47 | how to know this is mt62xx cpu and pin conecter is 1x12 cable just like same l12c i can used this cable but can not find tx&rx so pls help me urgent |
08-27-2008, 20:54 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i dont have anything for this type connector in my pinout colection. i can teach how to find pinout using multimeter, very easy procedure, just 5 min work |
08-28-2008, 14:20 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. set one multimeter probe to sone grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 3. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
08-29-2008, 05:33 | #10 (permalink) | |
Member: 59732 Status: Offline Thanks Meter: 47 | Quote:
COM31 [VCP4] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:009C:0C2F high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.232AD6FB.[A8_PCB01_GPRS_MT6226_S01.T90H_GY01_06_1_0T03_07122 7.BIN_82308E02].rpl ==================== New firmware detected: A8_PCB01_GPRS_MT6226_S01.T90H_GY01_06_1_0T03_07122 7.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 232AD6FB identification#1 protocol ver: 04 ver. sw1: A8_PCB01_GPRS_MT6226_S01.T90H_GY01_06_1_0T03_07122 7.BIN ver. sw2: T90H_GY01_06_1.0T03_071227, FD71CF7D ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:2BEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[A8_PCB01_GPRS_MT6226_S01.T90H_GY01_06_1_0T03_07122 7.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\ip168+eeprom[A8_PCB01_GPRS_MT6226_S01.T90H_GY01_06_1_0T03_07122 7.BIN]_20080828-212938.B0E flash: EC257E25082501:2BEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_232AD6 FB_A8_PCB01_GPRS_MT6226_S01.T90H_GY01_06_1_0T03_07 1227.BIN_82308E02_20080828-213025.B0X.bin Finished, time used: 395 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! RX=PIN.NO.7 TX=PIN.NO.6 GR=PIN.NO.1 SUCEESFUL ALIVE DEAD PHONE AGAIN THANKS TO INFINITY TEAM | |
The Following User Says Thank You to div_raj For This Useful Post: |
08-29-2008, 08:17 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! good to know now you collected very big experience. You found pinout yourself. now repair any chinese phone will easy job for you. Please send me full backup of this phone firmware to [email protected] |
08-29-2008, 16:21 | #12 (permalink) | |
08-29-2008, 21:48 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! my box can get such file without problems. also, you can upload it to www.rapidshare.com and post link here. |
08-30-2008, 08:17 | #14 (permalink) | |
yes u can download ip168+ flash file from here: http://rapidshare.com/files/14123475...11927.rar.html | |
08-30-2008, 19:35 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! thank you, file downloaded and will be included to our flash file collection |
Iphone A380 Pinout | ricson | Infinity-Box | 9 | 12-24-2008 06:43 |
Iphone Q380 Pinout Needed | kasim | Infinity-Box | 2 | 04-05-2008 11:10 |
cect iphone Q380 pinout need | kasim | Infinity-Box | 1 | 03-04-2008 09:09 |
iphone cable pinout | mrfixit | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 11-12-2007 22:00 |
