08-23-2009, 11:41 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: in my h.d.d
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | iphone range check error module v2.90 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: read NAND flash read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6230:8A02:8A02]... CPU: MT6230 high speed boot On chip: 0031:000F:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 0C loader: 3.0840.00.00 NAND id: EC795A3F page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 2000 external ram: 00000000 finalize connection... done emi configuration... ram size: 04000000 emi configuration done ram test... pass 1... pass 2... pass 3... pass 4... done NOR: 0000:000000000000 [00000000] NAND: 00EC:0079005A003F [08400000] NOR chip is not installed Initialize Done Set baud ... 460800 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00010000 bytes)... detecting bootloader structure... source data: page only rom info protocol ver: 04 ver. sw 1: APL228_PCB03_GPRS_MT6230_S02.APL228_20081218_V1_3. BIN ver. sw 2: APL228_20081218_V1.3, 00000000 ffs offset/size: 02000000/06000000 id-page1 Ok |
09-12-2009, 15:04 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
i have the same pn on 6228 NAND cpu.. range check error.. | |
09-13-2009, 20:47 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! we know about this problem and working under improving it update will follow nearest time |
10-27-2009, 21:13 | #5 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Azerbaijan Age: 38
Member: 68498 Status: Offline Thanks Meter: 152 | Any news about range check error fixing?Have an Iphone C900 on hand and range check error problem when detecting this detect standard fat offset pass #1... detect standard fat data... |
10-28-2009, 20:49 | #9 (permalink) |
Member: 68498 Status: Offline Thanks Meter: 152 | Here is the log. Code: ==== log opened: [10/27/2009 11:54:03 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] Chinese Miracle v2.93 S/N: ****:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [10/27/2009 11:54:35 PM] ==== COM6 [VCP0] selected module v2.93 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8503:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: E800_PXHT1F12_EVCOM2_MT6225S00.01_1_20090617.BIN ver. sw 2: E800_PXHT1F12.01.1, 00000000 ffs offset/size: 01C00000/00400000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent detecting ffs/eeprom structure pass 1... ........................ detect standard fat location pass #1... ....................................................... detect standard fat offset pass #1... detect standard fat data... ==== log opened: [10/28/2009 12:06:31 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] Chinese Miracle v2.95 S/N: ****:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [10/28/2009 12:06:59 AM] ==== COM6 [VCP0] selected module v2.95 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: "sp-unlock" unlock method: standard fast Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 29 sec Remove/Install battery now ! ==== log: [10/28/2009 12:07:48 AM] ==== COM6 [VCP0] selected module v2.95 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: "sp-unlock" unlock method: standard fast Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8503:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung D 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung D 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung D 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung D 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: E800_PXHT1F12_EVCOM2_MT6225S00.01_1_20090617.BIN ver. sw 2: E800_PXHT1F12.01.1, 00000000 address offset: 00000000 ffs offset/size: 01C00000/00400000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent detecting ffs/eeprom structure pass 1... ........................ detect standard fat location pass #1... ....................................................... detect standard fat offset pass #1... detect standard fat data... |
The Following User Says Thank You to systemworm For This Useful Post: |
Help china iphone copy 6230 NAND range check error | pitikor | Infinity-Box | 2 | 09-13-2009 20:47 |
motorola C168 range check error | vertex777 | Infinity-Box | 1 | 07-07-2008 21:23 |
Range Check Error | vijeeshkannur | Infinity-Box | 4 | 03-26-2008 15:13 |
C118 range check error | green bird | Infinity-Box | 1 | 02-13-2008 18:54 |
