05-12-2010, 18:02 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Iphone T757B-dead I've got this phone to change it's language package; I read fullflash from the phone,edited with language pack edit,saved full edited flash file and I wrote it to the phone. The operation was succesfully and the phone has powered on but some comands was changed(eg:"ok" and "back" was inverted) so I wrote back it's original flashfile but I get errors and the phone don't power on now. Code: COM4 [VCP2] selected module v3.13 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware E709_YP1_PCB01_GPRS_MT6235B_S01.01_0__fullflash_20100511-174830.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: E709_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection finished: Ok "format ffs" active interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0058]: 002C:00A100800095 [MICRON] MT29F1G08ABB chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 03000000/05000000 firmware size: 48Mb ffs size: 80Mb detect sec ro... detect custom parameters... detect project-id... project-id: E709_YP1.01.0 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: E709_BOOTLOADER_V005_MT6235B_01_1.bin warning: id-page1 area is invalid nfi area detection finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 05 sw version: E709_YP1_PCB01_GPRS_MT6235B_S01.01_0.BIN project-id: E709_YP1.01.0, 00000000 code offset: 00000000 ffs offset/size [01]: 03000000/05000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.13, database date: 02.05.2010): E709_YP1_PCB01_GPRS_MT6235B_S01.01_0.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... external bootloader is not present bootloader version: E709_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... error: can not write flash: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 7 min 7 sec Remove/Install battery now Regards! |
05-13-2010, 12:16 | #2 (permalink) |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | The problem is solved; I made format ffs whole flash chip and I wrote again it's original backup flashfile and the phone is working again Code: COM4 [VCP3] selected module v3.13 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware editor_corrected_editor_corrected_E709_YP1_PCB01_GPRS_MT6235B_S01.01_0__fullflash_20100511-174830.B4M.bin.B4M.bin.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... nfi scat area detected nfi area detection finished: Ok interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0058]: 002C:00A100800095 [MICRON] MT29F1G08ABB chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 03000000/05000000 firmware size: 48Mb ffs size: 80Mb detect sec ro... detect custom parameters... detect project-id... project-id: E709_YP1.01.0 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: E709_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 05 sw version: E709_YP1_PCB01_GPRS_MT6235B_S01.01_0.BIN project-id: E709_YP1.01.0, 00000000 code offset: 00000000 ffs offset/size [01]: 03000000/05000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.13, database date: 02.05.2010): E709_YP1_PCB01_GPRS_MT6235B_S01.01_0.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... nfi scat area detected nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 15 min 25 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to Burebista For This Useful Post: |
03-03-2011, 21:51 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! then you must attach full charged battery and keep power button pressed all the time while you do measurment |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
