Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2004 Location: In my country Age: 51
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Iphone4 Dual Sim Cant unlock please help me I get this problem when I try to unlock this phone. ************************************************** ******** COM3 [VCP0] selected module v3.26 Action: read unlock codes unlock method: read codes Model: Autodetect 6228-6253 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 16 sec Remove/Install battery now ! ************************************************** ******** Here is the link of the full flash read it. KST53_09A_PCB01_GPRS_MT6253_S00.MAUI_09A_W09_52_MP _V3__fullflash_20110207-030404.B0M.bin - 4shared.com - online file sharing and storage - download Many thanks for your fast solution.. |
![]() | #6 (permalink) |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Hi, again This is the log ![]() Action: "repair imei" Model: Autodetect 6253 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect") operation failed ! Finished, time used: 37 sec Remove/Install battery now ! Action: "repair imei" Model: Autodetect 6228-6253 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect") operation failed ! Finished, time used: 37 sec Remove/Install battery now ! |
![]() | #7 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Offline Thanks Meter: 13,684 | hello! change IMEI over bluetooth or get access to Engeneering menu and swith UART port to correct value IMEI change without cable over Bluetooth link step-by-step tutorial - GSM-Forum |
![]() | #8 (permalink) |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Hi, I try but ... Can you give me a correct link to download a BT Software please ? Other question plz... Can I use this method for unlock for example ZTE with Bluetooth ? Many thanks |
![]() | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 13,684 | hello! Unlock - no, only IMEI change. not format, not flash reading/writing. Use google for search BT software. i have it pre-installed in my IBM notebook. i dont have installer |
![]() | #10 (permalink) | |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Quote:
My laptop have installed the software ![]() Yes, only repair imei because for the others jobs need to boot with pwr off, I understand... Many thanks for all and best regards, Dany | |
Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-25-2009 17:29 |
