01-22-2018, 19:57 | #1 (permalink) |
No Life Poster Join Date: Jul 2011
Member: 1613469 Status: Offline Thanks Meter: 192 | IPRO KYLIN 5.0S Boot Error! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:00 Reconnect Power/Cable! |
05-17-2018, 14:42 | #4 (permalink) |
Freak Poster Join Date: Mar 2008 Location: colombia
Member: 738323 Status: Offline Sonork: 1618038 Thanks Meter: 69 | Exe version: NCKDongle AndroidMTK 2.5.8.7 Selected model: ELBRUS Action: Reset FRP Custom auth file added ok Will be used loader: DA_SWSEC.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM20) Boot mode: Preloader Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) UNKNOWN_EMMC_DEVICE EMMC FW VERSION: 12:00:00:00:00:00:00:00 EMMC CID: 8801034E4361726420 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM40) -Reading GPT Drive OK Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. |
05-17-2018, 15:46 | #5 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Next time check section carefully before posting. Br. Infinity Box Team. | |
09-18-2018, 21:57 | #6 (permalink) | |
Freak Poster Join Date: Jul 2016 Location: Chile Age: 41
Member: 2601431 Status: Offline Thanks Meter: 35 | Quote:
