12-16-2016, 19:49 | #1 (permalink) |
Freak Poster Join Date: Jun 2015
Member: 2413485 Status: Offline Thanks Meter: 14 | iq4412 quad read foto,video error without data lost Info: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 4B00011530305538DC39034DD780D788 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U8 [eMMC] : FLASH_CID : 1501004B385530304D0339DC88D780D7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x17B6597510D9411396EE0C31A3AB200F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Fly ProdName : Fly ProdModel : IQ4412 Quad Device : IQ4412 AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 SECURITY : IMEI_SW [1] : 8---------------- BTMAC Addr : E---------------- WiFi MAC : B------------------ MODEM : BaseBand : MT6589_S00_MOLY_WR8_W1248_MD_WG_MP_V6_P24 EXTRA : LCD [0] : gn_smd_s6e8aa LCD Res : 1280x720 TOUCH [0] : gn_melfas_mms144 CAM [0] : imx111_mipi_raw CAM [1] : ov5648_mipi_raw MODEM : WBW5886FY_gionee89_dwe_jb2_md1_hspa LOCALE : ru_RU en_US uk_UA xhdpi hdpi ldpi mdpi Done! Read phonebook book ok: Operation : Read UserData [ v1.58 ] PhoneBook : Enabled PhoneBook : VCFv3 Format output Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 4B00011530305538DC39034DD780D788 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U8 [eMMC] : FLASH_CID : 1501004B385530304D0339DC88D780D7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x17B6597510D9411396EE0C31A3AB200F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processiung : PhoneBook extraction Step #1 Step #2 Read Ok, PhoneBook records extracted : 728 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6583_PhoneBook.txt Write : 728 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6583_PhoneBook.csv VCF Saved to : C:\InfinityBox\CM2MTK\PhData\MT6583_PhoneBook.vcf VCFv3 Saved to : C:\InfinityBox\CM2MTK\PhData\MT6583_PhoneBook_v3.v cf Done! Elapsed: 00:00:47 Reconnect Power/Cable! If reset password without data lost: read patent/dp: [Info] : PatternLock Disabled! [Info] : DP Lock not set! Reset privacy lock: Checking data ... Not found any mount point, something went wrong When read foto,video error: If go reset user locks data lost? |
12-16-2016, 20:42 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Reset UserLocks just remove them, without touch data. Btw, if you can read full dump and send me - will revise that thing in Sw. |
12-17-2016, 11:31 | #5 (permalink) |
Member: 2413485 Status: Offline Thanks Meter: 14 | Phone unlock ok, data no lost, pack arhive https://yadi.sk/d/53ejPY7n33oumP |
