Old 10-12-2016, 11:15   #1 (permalink)
Member: 946381
Thanks Meter: 150
Istar i7 plus mtk6580 version 6-imei rebuild success-but still invalid imei
imei rebuild logs as below
Operation : Repair Security [ v1.51 ]
Wait for phone...
Phone found! [ 109 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 700100454838434538011EDB4BA473C5
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 8EC8H
[eMMC] : FLASH_CID : 700100454838434538011EDB4BA473C5
[eMMC] : FLASH_LEN : 0x00000001C8000000
[eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB]
DEV RID : 0x76D40596D1D06A2A02A77B903AB06ACD
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 355071501444535
IMEI [01] : 355071501444543
IMEI [02] : 861622010000056
IMEI [03] : 861622010000056
Set IMEI [00] : 353673058789402
Set IMEI [01] : 353673058789402
Prepare finished. Security check required!
Wait for phone...
Sync...
Repair done!
Done!
Elapsed: 00:00:38
Reconnect Power/Cable!
what i do as a next step?
The Following User Says Thank You to zone3 For This Useful Post:
Old 10-12-2016, 12:08   #2 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207(No More Use)
Thanks Meter: 706
Hello,
Check Baseband Then do repair imei..
The Following User Says Thank You to tapas770 For This Useful Post:
Old 10-13-2016, 04:38   #3 (permalink)
Member: 946381
Thanks Meter: 150
Originally Posted by tapas770 View Post
Hello,
baseband ok-details as below
molly.wr8.w1449.md.wg.mp.v6.p3-2015
Old 10-13-2016, 06:35   #4 (permalink)
BISMILLAH MOBILES's Avatar
Member: 610502
Sonork: 100.1618428
Thanks Meter: 161
Bro Zone3..
What was the condition of mobile before flashing?
Did you tried this phone on flashing and its done flashing with Normal ON?
Now IMEI write done but same is it your problem?
Solution:
Try to write same SPNV if available of that file which you used for flashing.
Your problem will be solved.
B/R
Sheraz...
Old 10-13-2016, 07:02   #5 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
Just Repair Baseband with Deep fix and try
Old 10-14-2016, 04:29   #6 (permalink)
Member: 946381
Thanks Meter: 150
Originally Posted by princesaddam View Post
Hello,
did-logs as below
Operation : Reinit Modem [ v1.51 ]
Wait for phone...
Sync...
Modem reinitialize done!
Done!
then again rebuild imei-logs as below
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Wait for phone...
Sync...
Repair done!
Done!
Elapsed: 00:00:46
first time on imei ok-again on and off imei invalid is my problem
Old 11-01-2016, 10:26   #7 (permalink)
GBKeyHelp's Avatar
Member: 1676092
Sonork: 100.1609037
Thanks Meter: 123
i also face the same problems
i think nv problems
Old 11-01-2016, 10:32   #8 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
What if make FactoryRests after?
The Following User Says Thank You to JayDi For This Useful Post:
Old 02-14-2017, 13:54   #9 (permalink)
Registered User
Member: 2072293
Thanks Meter: 9
same problem after reset factory data.first fews seconds show new imei but after comes old imei.
The Following User Says Thank You to THE SLUTE For This Useful Post:
Old 02-14-2017, 15:26   #10 (permalink)
Registered User
Member: 669673
Thanks Meter: 301
Unlock Bootloader first then try, may be it helpful for you.
The Following User Says Thank You to ravi mobile For This Useful Post:
Old 02-28-2017, 17:48   #11 (permalink)
Member: 1493682
Thanks Meter: 12
iStar i7
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Wait for phone...
Sync...
Repair done!
Done!
Elapsed: 00:00:38
Do you got solution, I have same phone and facing same problem,
after imei repair it shows new imei, but after restarting it same as old imei.
The Following User Says Thank You to smc_313 For This Useful Post:
Old 03-09-2017, 12:35   #12 (permalink)
Crazy Poster
Member: 2295090
Thanks Meter: 20
same problem for me too but my problem was solved after flashing
flash in sptool with format all+download
after flash nv ram data will be changed and after that imei repair we can do restart or factory resetting the imei will be same... with full bar of network signal
The Following User Says Thank You to ajjjuajjj For This Useful Post:
Old 03-09-2017, 13:11   #13 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
we Just Write MT6580 any NV file Problem Solve
Old 04-11-2017, 08:56   #14 (permalink)
Member: 1403528
Sonork: ghiklo
Thanks Meter: 7
Pls give me mt6580 nv filr
Sent from my P5L using Tapatalk
The Following User Says Thank You to mahinulhassan For This Useful Post:
Old 04-11-2017, 09:01   #15 (permalink)
Member: 1403528
Sonork: ghiklo
Thanks Meter: 7
I have same problem pls help
Page generated in 0.33961 seconds with 8 queries
