GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   Itel 1403 spd 7715 cant do anything Help me (https://forum.gsmhosting.com/vbb/f296/itel-1403-spd-7715-cant-do-anything-help-me-1994806/)
Kirumira 09-24-2015 15:35
Its problem was Forgot Patterns DRAW
http://s3.postimg.org/3nbkv2hm7/WP_20150918_001.jpg
Chinese Miracle II [SPD module] v 1.05
Start at : [18/09/2015 / 16:44:16]
Operation : Read PatternLock [ v1.05 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 52 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7715 Generic Loader NAND v1.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Checking Structure ...
Unknown structure detected! Something went wrong :(
If phone work normally - send report to support!
Elapsed: 00:00:29
Reconnect Power/Cable!
Operation : Format File System [ v1.05 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 52 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Error Init FL mode!
If phone work normally - check correct selection (Model,FlashType)!
Elapsed: 00:00:34
JayDi 09-24-2015 15:40
it eMMC. Try as SC7715 eMMC.
Kirumira 09-24-2015 15:58
its not EMMC.if you select spd7715 emmc software hang until you remove the cable
3. Insert cable
Phone found! [ 52 ]
Port Opened
Sync...
Sync...
Sending FDL
PASSIONATE_BOYS 09-24-2015 16:01
3. Insert cable
Phone found! [ 52 ]
Port Opened
Sync...
Sync...
Sending FDL
Hello,
In few cases it needs to select pac or sldr for read pattern or other operations.
Br.
Kirumira 09-24-2015 16:13
Originally Posted by PASSIONATE_BOYS (Post 11308148)
Hello,
Br.
Thanks bro,is Formatting requires select PAC OR SLDR??
I Think that Nand chip is not supported or need some revision by Jaydi
PASSIONATE_BOYS 09-24-2015 16:32
Hello,
For Format mostly it don't requires pac or sldr.
SPD Nand Format supported since V1.02. For now CM2 supports formatting for -SC7715/7730/7731/8830 Nand cpu's.
Br.
JayDi 09-24-2015 16:57
Again - it seems as NOT NAND.
If eMMC generic loader not support it - then need seek it pac or wait, when I make SLDR. ETA - from day for infinite. Because I not know, when find time to make it.
Kirumira 09-24-2015 17:29
thanks bro let me wait,
Page generated in 0.15099 seconds with 6 queries
