Old 09-24-2015, 16:35   #1 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,338
Itel 1403 spd 7715 cant do anything Help me
Its problem was Forgot Patterns DRAW
Chinese Miracle II [SPD module] v 1.05
Start at : [18/09/2015 / 16:44:16]
Operation : Read PatternLock [ v1.05 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 52 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7715 Generic Loader NAND v1.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Checking Structure ...
Unknown structure detected! Something went wrong
If phone work normally - send report to support!
Elapsed: 00:00:29
Reconnect Power/Cable!
Operation : Format File System [ v1.05 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 52 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Error Init FL mode!
If phone work normally - check correct selection (Model,FlashType)!
Elapsed: 00:00:34
Old 09-24-2015, 16:40   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,655
it eMMC. Try as SC7715 eMMC.
Old 09-24-2015, 16:58   #3 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,338
its not EMMC.if you select spd7715 emmc software hang until you remove the cable
3. Insert cable
Phone found! [ 52 ]
Port Opened
Sync...
Sync...
Sending FDL
Old 09-24-2015, 17:01   #4 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,978
3. Insert cable
Phone found! [ 52 ]
Port Opened
Sync...
Sync...
Sending FDL
Hello,
In few cases it needs to select pac or sldr for read pattern or other operations.
Br.
Old 09-24-2015, 17:13   #5 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,338
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
Thanks bro,is Formatting requires select PAC OR SLDR??
I Think that Nand chip is not supported or need some revision by Jaydi
Old 09-24-2015, 17:32   #6 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,978
Hello,
For Format mostly it don't requires pac or sldr.
SPD Nand Format supported since V1.02. For now CM2 supports formatting for -SC7715/7730/7731/8830 Nand cpu's.
Br.
Old 09-24-2015, 17:57   #7 (permalink)
JayDi's Avatar
Member: 462970
Again - it seems as NOT NAND.
If eMMC generic loader not support it - then need seek it pac or wait, when I make SLDR. ETA - from day for infinite. Because I not know, when find time to make it.
Old 09-24-2015, 18:29   #8 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,338
thanks bro let me wait,
Page generated in 0.28476 seconds with 7 queries
