12-09-2017, 15:52 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | itel A12 W507A-6.0-OP-EG-V035-20170825 firmware needed Model Name : itel_A12 Model Brand : Itel Model Device: itel_A12 AndrVersion : 6.0 BaseBand CPU: SP7731CEB_A12 CompileDate : 14/06/2017 07:20:34 Project Ver :A12-W507A-6.0-OP-EG-V035-20170825 Model Ext : itel A12 Anybody with it help me THANKXXXXX |
The Following 2 Users Say Thank You to Kirumira For This Useful Post: |
12-09-2017, 18:40 | #3 (permalink) | |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
its the same Upload it for me on Mediafire or Google-drive. Thankxxx sir. | |
12-10-2017, 12:07 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
12-16-2017, 16:16 | #9 (permalink) |
Junior Member Join Date: May 2017 Location: Ghana,Accra
Member: 2719134 Status: Offline Thanks Meter: 7 | ==== Wait for phone... Phone found! [ 42 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : itel_A12 Model Brand : Itel Model Device: itel_A12 AndrVersion : 6.0 BaseBand CPU: SP7731CEB_A12 CompileDate : 8/25/2017 5:19:52 AM Project Ver : A12-W507A-6.0-OP-EG-V035-20170825 Model Ext : itel A12 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:01:25 Reconnect Power/Cable! |
The Following User Says Thank You to Siirs For This Useful Post: |
12-18-2017, 20:21 | #10 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2688064 Status: Offline Thanks Meter: 1 | sir pls can i have the same file my cm2 reading is Phone found! [ 6 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : itel_A12 Model Brand : Itel Model Device: itel_A12 AndrVersion : 6.0 BaseBand CPU: SP7731CEB_A12 CompileDate : 8/25/2017 5:19:52 AM Project Ver : A12-W507A-6.0-OP-EG-V035-20170825 Model Ext : itel A12 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:22 Reconnect Power/Cable! |
12-20-2017, 12:25 | #11 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2156267 Status: Offline Thanks Meter: 0 | Can i av a perfect file that is 100% sure? ==== Wait for phone... Phone found! [ 148 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : itel_A12 Model Brand : Itel Model Device: itel_A12 AndrVersion : 6.0 BaseBand CPU: SP7731CEB_A12 CompileDate : 8/25/2017 5:19:52 AM Project Ver : A12-W507A-6.0-OP-EG-V035-20170825 Model Ext : itel A12 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:37 Reconnect Power/Cable! |
12-23-2017, 16:27 | #12 (permalink) |
Junior Member Join Date: Oct 2017 Location: Abidjan
Member: 2767457 Status: Offline Thanks Meter: 0 | please do you still have itel A12 file FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : itel_A12 Model Brand : Itel Model Device: itel_A12 AndrVersion : 6.0 BaseBand CPU: SP7731CEB_A12 CompileDate : 25/08/2017 05:19:52 Project Ver : A12-W507A-6.0-OP-EG-V035-20170825 Model Ext : itel A12 |
12-25-2017, 14:16 | #13 (permalink) |
01-03-2018, 17:15 | #15 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2557145 Status: Offline Thanks Meter: 0 | Card found: S/N : B31E12AF , v0136 Chinese Miracle II [SPD module] v 1.26 Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Check/Read Info [ v1.26 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : itel_A12 Model Brand : Itel Model Device: itel_A12 AndrVersion : 6.0 BaseBand CPU: SP7731CEB_A12 CompileDate : 8/25/2017 5:19:52 AM Project Ver : A12-W507A-6.0-OP-EG-V035-20170825 Model Ext : itel A12 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:39 Reconnect Power/Cable! |
