12-06-2017, 18:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Itel a12 write firmaware error HANG HERE WHEN TRYING TO FLASH thanks in advance. SCREENSHOT |
12-06-2017, 20:13 | #2 (permalink) |
No Life Poster Join Date: May 2014 Location: Nigeria
Member: 2192386 Status: Offline Thanks Meter: 50 | This could probably be hw error. Try booting phone in recovery mode. Sent from my SM-G610F using Tapatalk |
The Following User Says Thank You to adebayo0437 For This Useful Post: |
12-06-2017, 21:36 | #3 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Same with me Code: ========================= Start ========================= 04-12-2017 / 20:01:03 ========================================================= Card found: S/N : 5***** , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Loading : A12-W507A-6.0-OP-V006-20170316-RELEASE.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7720_UMS PacVersion : A12-W507A-6.0-OP-V006-20170316-RELEASE FastCheck : 0x009EC9A256 Loading files ... File : fdl1.bin File : fdl2.bin File : wnvitem.bin File : wcnnvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : persist.img File : userdata.img File : logo_AX45.bmp File : logo_AX45.bmp File : cache.img File : persist.img File : sysinfo.img File : u-boot.bin File : SC7720_UMS.xml Load Ok! Start at : [04-12-2017 / 20:02:38] Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : A12-W507A-6.0-OP-V006-20170316-RELEASE.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7720_UMS PacVersion : A12-W507A-6.0-OP-V006-20170316-RELEASE File : fdl1.bin File : fdl2.bin File : wnvitem.bin File : wcnnvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : persist.img File : userdata.img File : logo_AX45.bmp File : logo_AX45.bmp File : cache.img File : persist.img File : sysinfo.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Open Port Failed! Reconnect Power/Cable! Finish at : [04-12-2017 / 20:02:47] Start at : [04-12-2017 / 20:03:00] Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : A12-W507A-6.0-OP-V006-20170316-RELEASE.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7720_UMS PacVersion : A12-W507A-6.0-OP-V006-20170316-RELEASE File : fdl1.bin File : fdl2.bin File : wnvitem.bin File : wcnnvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : persist.img File : userdata.img File : logo_AX45.bmp File : logo_AX45.bmp File : cache.img File : persist.img File : sysinfo.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Open Port Failed! Reconnect Power/Cable! Finish at : [04-12-2017 / 20:03:06] Start at : [04-12-2017 / 20:03:27] Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : A12-W507A-6.0-OP-V006-20170316-RELEASE.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7720_UMS PacVersion : A12-W507A-6.0-OP-V006-20170316-RELEASE File : fdl1.bin File : fdl2.bin File : wnvitem.bin File : wcnnvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : persist.img File : userdata.img File : logo_AX45.bmp File : logo_AX45.bmp File : cache.img File : persist.img File : sysinfo.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x19 records PMTManager : PMT Update Failed!!! Selected firmware doesn't match to current HW or EMPTY battery! Flashing terminated! Elapsed: 00:00:46 Reconnect Power/Cable! Finish at : [04-12-2017 / 20:04:40] Start at : [04-12-2017 / 20:05:18] Operation : Flash Erase [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Erasig flash now, please wait ... ERROR : FLASH_FULL_FORMAT failed! Reconnect Power/Cable! Finish at : [04-12-2017 / 20:06:27] Set mode to : SP [SC773x] eMMC [Android 7.x] Start at : [04-12-2017 / 20:07:10] Operation : Format File System / Reset Settings [ v1.27 ] Start at : [04-12-2017 / 20:07:17] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC Loader v7 InfinityBox Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000012A1F7000 State : 0x0001 Mount : /cache Size : 0x0000000008F0D000 State : 0x0001 Error! ERROR : PART_FORMAT failed! Reconnect Power/Cable! Finish at : [04-12-2017 / 20:08:24] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Open Port Failed! Reconnect Power/Cable! Finish at : [04-12-2017 / 20:08:30] Set mode to : SP [SC773x] eMMC [Android 5.x] Start at : [04-12-2017 / 20:09:29] Operation : FlashIC ReadOnly/BadBlock Test [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [04-12-2017 / 20:10:01] Set mode to : SP [SC773x] eMMC [Android 6.x] Start at : [04-12-2017 / 20:10:29] Operation : FlashIC ReadOnly/BadBlock Test [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Prepare test data ... Test flow #0 ... Error on Flow Init! Battery/Connection problem? Test NOT PASSED! FlashIc is DAMAGED/BAD! ========================= Start ========================= 04-12-2017 / 20:12:50 ========================================================= Card found: S/N : 5**** , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP SC77xx [Model Select] Loading : A12-W507A-6.0-OP-V006-20170316-RELEASE.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7720_UMS PacVersion : A12-W507A-6.0-OP-V006-20170316-RELEASE FastCheck : 0x009EC9A256 Loading files ... File : fdl1.bin File : fdl2.bin File : wnvitem.bin File : wcnnvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : persist.img File : userdata.img File : logo_AX45.bmp File : logo_AX45.bmp File : cache.img File : persist.img File : sysinfo.img File : u-boot.bin File : SC7720_UMS.xml Load Ok! Start at : [04-12-2017 / 20:14:09] Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : A12-W507A-6.0-OP-V006-20170316-RELEASE.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7720_UMS PacVersion : A12-W507A-6.0-OP-V006-20170316-RELEASE File : fdl1.bin File : fdl2.bin File : wnvitem.bin File : wcnnvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : persist.img File : userdata.img File : logo_AX45.bmp File : logo_AX45.bmp File : cache.img File : persist.img File : sysinfo.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 44 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Error : ChangeBaud Failed! Use default : 460800 bd! |
01-11-2018, 12:12 | #6 (permalink) | |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | ]@ Quote:
many firmware and cpu for this A12 | |
01-12-2018, 12:06 | #7 (permalink) |
Freak Poster Join Date: Jun 2016
Member: 2592600 Status: Offline Thanks Meter: 19 | doing flash ic test could have saved u from this strees... 99% of this phone i have come across stuck on Itel Logo, all did not pass flash ic test..always stops at 83%. SO MAJORITY OF THE PHONES HAVE HARDWARE ERROR so no need for flashing. |
01-13-2018, 07:52 | #9 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
02-21-2018, 11:49 | #12 (permalink) |
Freak Poster Join Date: Jul 2017 Location: douala cameroon
Member: 2741861 Status: Offline Thanks Meter: 5 | the same problem please did you finally soft your problem if yes bro also provide me the solution. i have the same problem with itel a12 thats the same trouble i encountered when trying to flash with cm2 |
The Following User Says Thank You to apah richie For This Useful Post: |
07-24-2018, 16:24 | #15 (permalink) | |
No Life Poster Join Date: Nov 2014 Location: Kampala,Uganda
Member: 2294589 Status: Offline Thanks Meter: 116 | Quote:
Hey please follow this link https://www.9jarom.com/download-the-...der-free-here/ download that flash tool extract it on your pc, run it then load the flash file follow what it tell you to do when it starts to flash But note press thank button | |
