02-28-2018, 07:52 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Jammu & Kashmir (India)
Member: 367928 Status: Offline Thanks Meter: 178 | itel A42plus, fleshing fail, even readed file by cm2 Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 26 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : U267 Model Brand : Itel Model Device: itel-A42Plus AndrVersion : 7.0 Project Ver : A42Plus-U267P-7.0-IN-V007-20170922 Model Ext : itel A42 Plus [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : nvitem_l.bin [Read Ok] : sc983x_cp1.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : l__WPH_arm7.bin [Read Ok] : PM_arm7_sys.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : wcn_fdl.bin [Read Ok] : AA_MARLIN.bin [Read Ok] : boot.img [Read Ok] : trustos.bin [Read Ok] : vmm.bin [Read Ok] : system.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 3008 MiB Saved to : C:\ANDROID\SC77xx_itel-A42Plus_7.0_A42Plus-U267P-7.0-IN-V007-20170922_itel_A42_Plus\ Done! Elapsed: 00:10:45 Reconnect Power/Cable! Infinity SC Firmware Detected FW Size : 3008 MiB Load Ok! File Info Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : Itel Device Model : itel-A42Plus Device IntName : U267 Device Version : 7.0 Device Compile : 9/24/2017 2:31:38 PM Device Project : A42Plus-U267P-7.0-IN-V007-20170922 Device ExtInfo : itel A42 Plus Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 26 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x1B records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... [FlashProc] : Error with code 0x027E00A20000FF5D7E Elapsed: 00:00:37 Reconnect Power/Cable! try with update NVM and with nv, still same try with pac file but again error try with three different files Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : A42Plus-U267P-7.0-IN-V010-20171106.pac CRVersion : BP_R1.0.0 PacCPUinfo : SharkLSGLobalMarlinAndroid5.1 PacVersion : A42Plus-U267P-7.0-IN-V010-20171106 File : fdl1.bin File : fdl2.bin File : ltenvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : ltemodem.bin File : ltedsp.bin File : ltegdsp.bin File : ltewarm.bin File : pmsys.bin File : wcnfdl.bin File : wcnmodem.bin File : boot.img File : tos_2g.bin File : vmm.bin File : recovery.img File : system.img File : userdata.img File : log.bmp File : log.bmp File : cache.img File : persist.img File : sysinfo.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 26 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x28 records PMTManager : PMT Update Failed!!! Selected firmware doesn't match to current HW or EMPTY battery! Flashing terminated! Elapsed: 00:00:25 Reconnect Power/Cable! problem hang on logo, with update tool R19 .0001 NV_WLTE top error |
02-28-2018, 08:06 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Test Emmc R/O and post logs here,, seems ur Emmc damage |
The Following User Says Thank You to princesaddam For This Useful Post: |
02-28-2018, 08:16 | #3 (permalink) | |
Member: 367928 Status: Offline Thanks Meter: 178 | Quote:
==== Wait for phone... Phone found! [ 26 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Prepare test data ... Test flow #0 ... Error on Flow Init! Battery/Connection problem? Test NOT PASSED! FlashIc is DAMAGED/BAD! Elapsed: 00:00:41 Reconnect Power/Cable! | |
02-28-2018, 10:35 | #4 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
As shown in logs it's FlashIC problem. Br. Infinity Box Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
