04-09-2009, 17:11 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Monrovia
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | ITEL C8000 can't unlock.......???? here is log...... COM3 selected module v2.79 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001E03:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: M5525_PCB01_GPRS_MT6225_S00.M5525_L01_20081022.BIN ver. sw 2: M5525_L01_20081022, 00000000 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. .................................................. .................................................. .................................................. ...... security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ....................... detect standard fat location pass #1... ................................................ detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[M5525_PCB01_GPRS_MT6225_S00.M5525_L01_20081022.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[M5525_PCB01_GPRS_MT6225_S00.M5525_L01_20081022.BIN]_20090409-155307.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... Special operation Done Write ... flash: 01227E22202200:18E59F00000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 237 sec Remove/Install battery now ! i try with both method standard and standard fast but same result |
7370 can't unlock and can't read simlock status with cyclone box !! | wgmmmx | Cyclonebox | 10 | 05-21-2009 13:13 |
Can't Unlock and can't read flash my433v | said4 | SMTi | 1 | 05-20-2009 04:54 |
nec e122 can't unlock can't flash ??????????????? | patric | FuriousGold | 7 | 01-23-2009 21:52 |
V66 can't unlock can't flash | Keke | Motorola P2k | 4 | 06-16-2003 10:17 |
A35-can't flash, can't unlock, can't log! | Migeni | x1x to x45/x50 | 4 | 12-21-2002 12:17 |
