Old 11-17-2018, 14:53   #1 (permalink)
Member: 1503666
Thanks Meter: 30
itel1408 stuck on factory mode
i have flashed this itel 1408 but still remain in this state have received many handset in this phone without success if anyone has solution kindly share
https://photos.google.com/photo/AF1Q...nqOsMJaPNKx178
Old 11-17-2018, 16:18   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Post software logs text here.
The Following User Says Thank You to Kirumira For This Useful Post:
Old 11-19-2018, 08:59   #3 (permalink)
Member: 1503666
Thanks Meter: 30
attached is the log
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 21 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.43.3_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:08:19
Old 11-19-2018, 09:09   #4 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Read info from your phone,if same like this i will upload it for you
SP7731GEA_IT1408_itel_it1408C_5.1_IT1408-W404-20160902_itel_it1408
Old 11-19-2018, 10:46   #5 (permalink)
Member: 1503666
Thanks Meter: 30
i have attached the info
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Operation : Check/Read Info [ v1.27 ]
3. Insert cable
Phone found! [ 21 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : itel_it1408C
Model Brand : Itel
Model Device: itel_it1408C
AndrVersion : 5.1
BaseBand CPU: SP7731GEA_IT1408
CompileDate : 7/5/2016 3:17:42 AM
Project Ver : IT1408-W404-20160705
Model Ext : itel it1408
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:30
i have flashed the set without sucess always stuck on logo then it goes to factory mode
Old 11-19-2018, 11:14   #6 (permalink)
Member: 1503666
Thanks Meter: 30
i have flashed the set without sucess always stuck on logo then it goes to factory mode i used this version SP7731GEA_IT1408_itel_it1408C_5.1_IT1408-W404-20160705_itel_it1408
Old 11-19-2018, 14:51   #7 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
WHAT WAS PHONE PROBLEM BEFORE FLASH?
Make FLASH IC R/O CHECK service tab
Old 11-19-2018, 16:32   #8 (permalink)
Member: 1503666
Thanks Meter: 30
Phone found! [ 21 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
Prepare test data ...
Test flow #0 ...
Test flow passed!
Test flow #1 ...
Test flow passed!
Test flow #2 ...
Test flow passed!
Test flow #3 ...
Test flow passed!
Test flow #4 ...
Test flow passed!
Test flow #5 ...
Test flow passed!
Finalize Ok!
Test passed successfully!
Elapsed: 00:00:24
attached is the log
Old 11-19-2018, 16:44   #9 (permalink)
Member: 1503666
Thanks Meter: 30
[QUOTE=Kirumira;13424628]WHAT WAS PHONE PROBLEM BEFORE FLASH?
Make FLASH IC R/O CHECK service stuck on logo then it goes to factory mode
Old 09-29-2022, 07:42   #10 (permalink)
FREDDIE GTY's Avatar
Member: 1340870
Sonork: 1611357
Thanks Meter: 148
Thumbs up pliz upload this file
upload this file ibadly need it
Old 09-29-2022, 10:18   #11 (permalink)
Member: 1043909
Thanks Meter: 60,926
There are three IT1408 files at Infinity server, get it https://infinity-box.com/support/
Page generated in 0.19779 seconds with 8 queries
