03-27-2017, 13:45 | #1 (permalink) |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Itel it5622 Code: Chinese Miracle II [SPD module] v 1.24 Operation : Read User Code [ v1.24 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0017 0000 [0] Flash VEN : Winbond , W25Q64 [0] Flash CAP : 00800000 Check data... Can take some time User Code : 147258 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.24 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0017 0000 [0] Flash VEN : Winbond , W25Q64 [0] Flash CAP : 00800000 Read Flash Content Read Ok , collect info Platform : MOCOR_12C.W13.04.14_Debug G243_it5622_64X64_240X320BAR_EnFrPoArSwHa Project : IT5622-G243-EnFrPoArSwHa-20160630 HWInfo : fp6531_bar Compile : 06-30-2016 21:52:33 Set FileInfo : Model Vendor : Itel Model Name : it5622 ExtInfo Data : Eng Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MOCOR_12C.W13.04.14_Debug_G243_it5622_64X64_240X320BAR_EnFrPoArSwHa_06302016215233_Eng__Itel-5622.bin Done! Elapsed: 00:00:57 Reconnect Power/Cable! |
