Old 07-28-2017, 19:17   #1 (permalink)
Member: 367928
Thanks Meter: 178
itell 1508 imei writen ok but still imei null
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Repair Security [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 21 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
Write new security data :
IMEI1 : 352000000020047
IMEI2 : 352300000000054
Step #1 Ok
Step #2 Ok
Write done!
Elapsed: 00:00:28
Reconnect Power/Cable!
imei still null
baseband is ok
Old 07-29-2017, 04:28   #2 (permalink)
Member: 2596993
Thanks Meter: 5
Try in diag mode
Sent from my SM-A510F using Tapatalk
Old 07-29-2017, 08:19   #3 (permalink)
Member: 367928
Thanks Meter: 178
Originally Posted by joshil View Post
Try in diag mode
fail always....................
Old 07-29-2017, 08:20   #4 (permalink)
Member: 2596993
Thanks Meter: 5
Check drivers
Old 07-29-2017, 08:46   #5 (permalink)
Member: 1962832
Thanks Meter: 199
3. Insert cable
Phone found! [ 21 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Step #1 Ok
Step #2 Ok
Write done!
Elapsed: 00:00:28
imei still null
baseband is ok
first flash phone after try :https://firmwarefile.com/itel-it1508
Old 07-29-2017, 18:04   #6 (permalink)
Member: 367928
Thanks Meter: 178
sir I already flesh it, change drivers but still same
Old 07-29-2017, 20:23   #7 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
Tick update nvm and flash then try again also post flashing logs also
Sent from my S_plus using Tapatalk
Old 07-30-2017, 12:46   #8 (permalink)
Member: 367928
Thanks Meter: 178
Originally Posted by princesaddam View Post
Hello,
still same
Loading : IT1508-C160-IN-20160330.pac
CRVersion : BP_R1.0.0
PacCPUinfo : SC77xx_no_internal_sd
PacVersion : IT1508-C160-IN-20160330
FastCheck : 0x006399618C
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : nvitem_wcn.bin
File : prodnv.img
File : u-boot-spl-16k.bin
File : SC7702_pike_modem.bin
File : DSP_DM_G2.bin
File : SC8800G_pike_wcn_dts_modem.bin
File : boot.img
File : recovery.img
File : system.img
File : oem.img
File : persist.img
File : sysinfo.img
File : userdata.img
File : logo.bmp
File : logo.bmp
File : cache.img
File : u-boot.bin
File : SC77xx_no_internal_sd.xml
Load Ok!
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : IT1508-C160-IN-20160330.pac
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : prodnv.img
File : boot.img
File : recovery.img
File : system.img
File : oem.img
File : persist.img
File : sysinfo.img
File : userdata.img
File : logo.bmp
File : logo.bmp
File : cache.img
File : u-boot.bin
3. Insert cable
Phone found! [ 91 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
PMTManager : Load 0x1A records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : NVM Update
Current ID : NV_W
Current Part : wfixnv1
[FlashProc] : Ok!
Current ID : NV_WCN
Current Part : wcnfixnv1
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : SC7702_pike_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : DSP_DM_G2.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : SC8800G_pike_wcn_dts_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : OEM
Current File : oem.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : PERSIST
Current File : persist.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : SYSINFO
Current File : sysinfo.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : logo.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
Current ID : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:07:05
3. Insert cable
Phone found! [ 91 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
IMEI1 : 35238000000054
IMEI2 : 35230000000000047
Step #1 Ok
Step #2 Ok
Write done!
Elapsed: 00:00:59
Old 07-30-2017, 13:10   #9 (permalink)
Member: 1962832
Thanks Meter: 199
still same
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : prodnv.img
File : boot.img
File : recovery.img
File : system.img
File : oem.img
File : persist.img
File : sysinfo.img
File : userdata.img
File : logo.bmp
File : logo.bmp
File : cache.img
File : u-boot.bin
Load Ok!
======= Flash
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : prodnv.img
File : boot.img
File : recovery.img
File : system.img
File : oem.img
File : persist.img
File : sysinfo.img
File : userdata.img
File : logo.bmp
File : logo.bmp
File : cache.img
File : u-boot.bin
3. Insert cable
Phone found! [ 91 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Flashing now
Current ID : NV_W
[FlashProc] : Ok!
Current ID : NV_WCN
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
[FlashProc] : Ok!
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : OEM
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH
[FlashProc] : Ok!
[FlashProc] : ERASE
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current Part : misc
[FlashProc] : Ok!
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:07:05
3. Insert cable
Phone found! [ 91 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Step #1 Ok
Step #2 Ok
Write done!
Elapsed: 00:00:59
write nvram file solved ur problem
Old 07-30-2017, 16:17   #10 (permalink)
Member: 367928
Thanks Meter: 178
share nvram if have please
Old 07-30-2017, 16:27   #11 (permalink)
wutangclan33's Avatar
Member: 1616754
Thanks Meter: 245
Have you tried to write with factory download?
not research download...
this factory download
Old 07-30-2017, 23:59   #12 (permalink)
Member: 2336625
Thanks Meter: 6
Just needs to write NVRAM either from a working phone or the pac file
Old 08-04-2017, 19:23   #13 (permalink)
Member: 367928
Thanks Meter: 178
yes sir I flesh it with this tool but still same
Old 08-04-2017, 19:27   #14 (permalink)
Member: 367928
Thanks Meter: 178
how can write nvram from pac file, i update nv while fleshing, cleir DIN DATA, but still imei null, flesh with two diffrent file, baseband ok
Old 08-04-2017, 19:48   #15 (permalink)
Member: 1972648
Thanks Meter: 45
no other way spd hard to fix u need a working phone
hello bro just read NVM backup from working phone and write
done
next time be care off all spd cpu dont flash or unlock frp or network unlock
without nvm backup becoz now dys All box dongles in spd work like free tools
thanks
The Following User Says Thank You to zzaheerr For This Useful Post:
Page generated in 0.26529 seconds with 8 queries
