06-19-2019, 09:18 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: india Age: 44
Member: 1090739 Status: Offline Sonork: Hossne Mamun Thanks Meter: 19 | Ivoomi i2 dead after flesh..how solw this problem..any solution plz Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v123080 Ok! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : ivoomi : I2 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC_AC.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 0004 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH_MISMATCH Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
06-19-2019, 09:39 | #2 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | exe not yet flashed handset, according to your log then how dead long hold key or reconnect battery handset stuck in sw mode |
The Following User Says Thank You to kamal_singla For This Useful Post: |
06-19-2019, 12:06 | #3 (permalink) |
Member: 1090739 Status: Offline Sonork: Hossne Mamun Thanks Meter: 19 | only make.. MediaTek USB Port (COM4) all proses but stil same...then how dead long hold key or reconnect battery handset stuck in sw mode |
