Old 05-08-2007, 10:24   #1 (permalink)
VIVEK's Avatar
Member: 4491
Thanks Meter: 4
w210 can't flash
i have mot w210 phone locked-please contact service center
when i try to flas it software says rang chack errer
any sol. pls
thanks
vivek
The Following User Says Thank You to VIVEK For This Useful Post:
Old 05-08-2007, 10:35   #2 (permalink)
VIVEK's Avatar
Member: 4491
Thanks Meter: 4
COM4 selected
Device: Motorola-W210
Checking data, wait...
connection mode: "Emergency mode" connection
Action: Flash write
"smart write" enabled
"safe mode" enabled
Write: Firmware
Write: Flex/Customization
Write: Language pack
Skip: FFS/File system
Skip: Eeprom
Connect...
Phone must be Powered-Off
Connecting, wait...
Connecting, wait...
Connect Done
Initialize...
detecting chip[01]...
flash: 89885500010001
flash: 89885500000000
flash: Intel 28F640W30-B B 8Mb
Release Power button now !
Initialize Done
Set baud...
921600
Set baud Done
Check parameters...
Reading [Motorola-W210_eeprom]...
file saved: backup_Motorola-W210_eeprom_20070508-150649.B2E.bin
software version: 1.0.04.
hardware version: MOTOROLA_A67
try with standared cann. and emergency cann.and reapir mode but same problem
Old 05-08-2007, 19:57   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please, try to use this beta software and let me know about results.
http://www.infinity-box.biz/public/I...dule_v1.11.rar
Old 05-09-2007, 07:08   #4 (permalink)
Member: 284196
Sonork: 100.1640403
Thanks Meter: 250
Originally Posted by InfinitySupport View Post
Hello,
same problem pls chk att file
Old 05-09-2007, 07:52   #5 (permalink)
Member: 130995
Hello,
Please, go to "Settings" page, UN-check "Backup system area" box and repeat operation.
Please, inform me about results.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 05-09-2007, 11:08   #6 (permalink)
VIVEK's Avatar
Member: 4491
Thanks Meter: 4
Hello,
after this phone flash ok but stell phone locked -contactservice center
[COLOR=#ff0000]hear is log
[COLOR=black]COM2 selected
connection mode: Standard connection
Action: Flash write
"safe mode" enabled
Write: Firmware
Skip: Eeprom
Connect...
Connecting, wait...
Connecting, wait...
Connect Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Check parameters...
flex version: FF_A67_0101_1408
LP version: LPH_A67_ASIA2_018
Check parameters Done
Check flash...
Check flash Done
Write...
Area: Firmware
Write: Firmware
"safe mode" active
Area: Flex/Customization
Area: Language pack
Write Done
Finished, time used: 641 sec
Remove/Install battery now
Old 05-09-2007, 11:17   #7 (permalink)
Member: 130995
Hi,
try to use files ver 1.2.13
also, please, send flash backup and "operation.log" file to [email protected]
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 05-09-2007, 14:43   #8 (permalink)
Member: 284196
Sonork: 100.1640403
Thanks Meter: 250
Mobile Is Ok With Ver. 1.2.13 Thanks But Where I Can Find English Lag.?
Vivek
Old 05-09-2007, 16:42   #9 (permalink)
Member: 130995
I am not sure about w210, but for w200 procedure (try and tell me results):
Set English lang:
Menu
Down 7 times, Right soft button
Down 3 times, Right soft button
Down 1 times, Right soft button
Down 4 times, Right soft button
select language now
Old 05-10-2007, 06:29   #10 (permalink)
VIVEK's Avatar
Member: 4491
Thanks Meter: 4
not working with w210
vivek
Old 05-10-2007, 10:01   #11 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
then you have to find this in "blind". had done this with many phones, maximum 10min of work
Old 09-30-2008, 14:12   #12 (permalink)
jagdish puri's Avatar
Member: 573120
Thanks Meter: 145
w210 motorola english lag
Vivek
go to setting 5 times down then press ceter key , then 4 times down press center key , one time down means middel of 3 options then again press center key . english languge ll done
Old 07-07-2010, 09:22   #13 (permalink)
gsm_jeevan's Avatar
Member: 773423
Thanks Meter: 82
vivek
select "emergency mode connection " when phone not connected
COM6 [VCP0] selected
Action: Flash write
"safe mode" enabled
Write: Firmware
Skip: Eeprom
Connect...
Connecting, wait...
Connecting, wait...
Connect Done
Initialize...
flash: 89885500010001:89885500000000
Initialize Done
Set baud...
115200
Set baud Done
Check parameters...
reading [Motorola-W210_eeprom]...
file saved: C:\Program Files\InfinityBox\QCModule\Motorola-W210_eeprom_20100707-132558.B2E.bin
ESN: 147C54A4
Check flash...
Check flash Done
Write...
Area: Firmware
Write: Firmware
"safe mode" active
Area: Language pack
Write Done
Finished, time used: 701 sec
Remove/Install battery now !
Vivek
centre button 1 time (menu )
down button 1 time (setting )
centre button 1 time selectinf setting )
down button 5 time (initial setup )
centre button 1 time (seleting initial setup )
down button 4 time (language)
centre button 1 time (selecting language )
down button 1 time ( english )
centre button 1 time (selecting english )
thats all
thanks to infinity team
The Following User Says Thank You to gsm_jeevan For This Useful Post:
Can't flash NEC 338 angel25dz NEC 0 03-29-2010 12:25
A35-can't flash, can't unlock, can't log! Migeni x1x to x45/x50 4 12-21-2002 12:17
Page generated in 0.38749 seconds with 10 queries
