j100i phone is hacked hi 2 all j100i after flash phone is hacked. i flashed R1A002,R1C004, R1E004. STILL SAME PROBLEM, AFTER FLASH I DO IME REPAIR, FFS FORMATE, UNLOCK PHONE IS HACKED PLZ HELP ME ONY ONE THIS SOLUTION |
hello! flash phone with version R1A002 with correspondent LP and Flex. then push change IMEI with "restore" checked. make unlock. Phone must be ok after this |
no way I tried all ways still PHONE IS HACKED INFINTYHELP please tell me if phone is hacked can we repair with infinity? |
sory sir mobile working fine. infinity is great & support is very very great. thanks regards |
hello! please post here how did you solve your problem. which flash files you used, what operation did |
J100i phone is hacked hello sir i hv used the same version for flash nd eprom as well nd method given by u but phone still same phone hacked what should i do i m sending u the following log: COM3 [VCP0] selected Action: unlock Device: Sony-Ericsson J100 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... startup condition detected SW version: R1A002 HW version: _NC2 LP ver: CXC1250396_lp_EU2_R1A002 Flex ver: FFN_NC2_01_FILE 999 imei otp: 359210006027363 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _359210006027363_20080617-223205.80E.bin imei eeprom: 0173930FA79DD05 error: non-locked or unknown eeprom Check Flash-2 Fail Finished, time used: 29 sec Remove/Install battery now ! what should i do? plz help me infinity team........ |
Hello imei eeprom: 0173930FA79DD05 imei otp: 359210006027363 IMEI is corrupt... rewrite correct IMEI Thanks .....my INFINITY box arrives on FRIDAY! ;smokin |
1. make eeprom backup for emergency case 2. write repair eeprom from support area 3. repair imei |
just repair the IMEI no with restore option ticked. I have just done it and phone is working fine. this is log COM5 [VCP0] selected Action: imei repair new imei: 354155011698754 Device: Sony-Ericsson J100 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: R1D009 HW version: _NC2 LP ver: CXC1250384_lp_INDIA_R1D0 Flex ver: FFN_NC2_01_FILE imei otp: 354155011698754 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _354155011698754_20080709-131639.80E.bin imei eeprom: 354155011698754 reading ... Check Flash-2 Done Write... Finalizing... Write Done Finished, time used: 62 sec Remove/Install battery now ! |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Action: unlock Device: Sony-Ericsson J100 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[04]: general communication fault. Release Power button ! Connect Fail Finished, time used: 12 sec Remove/Install battery now ! sir i m unlocking the phone but recieve this error what am i do pls sir help me |
restore IMEI........... |
Keyboard top 1.........12 9: Gnd 10: phone Rx 11: phone Tx |
hi sir i did full flash then change imei ok every thing is ok but phone asked phone is hacked plz help me thx |
Hello, Repair imei to it\'s original value (that you can see by imei otp: xxx text in log) |
