j110 eprom damaged j110 in flash Probably wrong model selected, Do you want to continue ?Probably wrong model selected, Do you want to continue ? after full flash and repair and sp unlock phone eprom damaged and error Probably wrong model selected, Do you want to continue ? |
when repair phone this error COM3 [VCP2] selected Device: Sony-Ericsson J120i "advanced chip detection" active Action: repair Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: version sw: Check flash Done Check parameters... reading Sony-Ericsson J120i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J120i_eeprom_calibration-1_20090427-114123.6AE.bin Check parameters Done Check data... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data Done Writing... .error: required data not found or unknown eeprom structure Writing Fail Finished, time used: 11 sec Remove/Install battery now ! |
Hello, Flash phone with any "repair eeprom" file from support area and then make "Repair" operation. |
COM3 [VCP3] selected Device: Sony-Ericsson J110i "advanced chip detection" active Action: flash write Skip: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Write: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: !) version sw: LB Check flash Done Check parameters... reading Sony-Ericsson J110i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J110i_eeprom_calibration-1_20090427-203642.6AE.bin Check parameters Done Check data... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data Done Writing... Area: Eeprom flash: 89886200010001:89886200000000 Write: Eeprom Writing Done Finished, time used: 19 sec Remove/Install battery now ! COM3 [VCP3] selected Device: Sony-Ericsson J110i "advanced chip detection" active Action: repair Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: !) version sw: LB Check flash Done Check parameters... reading Sony-Ericsson J110i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J110i_eeprom_calibration-1_20090427-203727.6AE.bin Check parameters Done Check data... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data Done Writing... .error: required data not found or unknown eeprom structure Writing Fail Finished, time used: 11 sec Remove/Install battery now ! but phone has eeprom damaged and error warning: Probably wrong model selected, Do you want to continue ? |
Hello, What was with phone before flash ? Is it was good working or dead phone ? |
before flash phone is dead |
any body helpme please sulotion for this problem urgent |
Hello, As I can see from your previous log phone has problems after you have flashed it (model mismatch after flashing). This means that your phone has hardware problems. You must open phone and repair it's hardware. |
hi tanx support for reply |
