10-27-2007, 08:53 | #1 (permalink) |
Freak Poster Join Date: Jul 1999 Location: Bulgaria
Member: 327 Status: Offline Thanks Meter: 6 | J110i cant unlock COM10 [VCP1] selected Device: Sony-Ericsson J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 100C-000 version sw: KIM-5- Check flash Done Check parameters... reading Sony-Ericsson J110i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J110i_eeprom_calibration-1_20071027-103344.6AE.bin Check parameters Done Check data... Check data Done Writing... flash: 89886200010001:89886200000000 Write: eeprom error: no any expected answer error: flash write error: 003F2000:00002000 Writing Fail Finished, time used: 43 sec Remove/Install battery now ! BR PS |
10-27-2007, 14:32 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hi, check battery voltage, open phone and check water inside. Also probably need to reball flash chip. It's just an idea, dut I do't see any other reason that eeprom can't be written. Also, read flash and send flash backup and original eeprom backup file (backup_Sony-Ericsson J110i_eeprom_calibration-1_20071027-103344.6AE.bin) to [email protected] to check |
10-28-2007, 11:43 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | Hello My j11oi still asking for correct sim card.. any idea of this problem??? Thnx for quick support from Infinity Team HModule v1.07 COM1 [Serial0] selected Device: Sony-Ericsson J110i Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 039C-000 HW ver: KIM-5- Check Flash Done Check Parameters... file saved: backup_eeprom_calibration_20071028-033848.6AE.bin Check Parameters Done Check Space... Flash: 0089:886200010001 flash: Intel 28F320W18-T T 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Writing Done Finished, time used: 49 sec Remove/Install battery now ! |
10-28-2007, 18:17 | #4 (permalink) |
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | thnx bro i need solution on infinity... y it cant b unlock by this method?? Last edited by InfinitySupport; 10-29-2007 at 01:41. |
10-29-2007, 01:40 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @khem you are good joker. You write that you use HModule but in fact you have used old MModule software. You must download, install and run HModule v1.07 from support are ! @ekrem Infinity-Box J110/J120 solution is perfect and can unlock/repair any J110/J120 w/o any problems. Btw, don't you think that yo are little bit in wrong section ? If you respect nobody why you think than people will respect you ? p.s. your message deleted, no reason to see here such "help" from you. |
10-29-2007, 11:05 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @gsmcobra you must thisk before write. If you really have problems - just explain the problem and I'll tell you what is your mistake and your problem will be solved in 1 minute. If you have no real problem but just want to increase number of your posts - you are in wrong section. p.s. your message was deleted due to I don't want to see here your stupid advertizing messages. |
10-29-2007, 12:03 | #8 (permalink) |
Member: 327 Status: Offline Thanks Meter: 6 | Sorry for my delay. Phone battery is full chaged.No water inside.Phone is brand new. I try with other tool for read codes and direct unlock and also not work. I will send backups. BR PS |
11-02-2007, 11:31 | #10 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Ha Noi - Viet Nam Age: 18
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | I just have done ok one J110i . Thanks infinity teams. ==== log opened: [11/2/2007 5:10:18 PM] ==== Application: C:\Program Files\InfinityBox\HModule\HModule.exe Loading data, wait... [Infinity Box] v1.07 S/N: xxxxxx Wait... Current model: Sony-Ericsson J110i Done COM30 ready COM30 [VCP1] selected Device: Sony-Ericsson J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: KIM-5- Check flash Done Check parameters... reading Sony-Ericsson J110i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J110i_eeprom_calibration-1_20071102-171149.6AE.bin Check parameters Done Check data... Check data Done Writing... flash: 89886200010001:89886200000000 Write: eeprom Writing Done Finished, time used: 13 sec Remove/Install battery now ! |
11-02-2007, 18:59 | #11 (permalink) |
Freak Poster Join Date: Sep 2004 Location: where dreams become reality
Member: 83567 Status: Offline Thanks Meter: 2 | i get this error what do i do, i cant even repair, phone now shows authorized phone. Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: KIM-5- Check flash Done Check parameters... reading Sony-Ericsson J110i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J110i_eeprom_calibration-1_20071102-185352.6AE.bin Check parameters Done Check data... Check data Done Writing... ....error: required data not found or unknown eeprom structure Writing Fail Finished, time used: 14 sec Remove/Install battery now ! |
11-02-2007, 19:45 | #13 (permalink) |
Member: 83567 Status: Offline Thanks Meter: 2 | hey, i downloaded eeprom , wrote eeprom, repaired then unlocked and voila phone is unlocked, nice support infinity u guys never end, guess thats why u are infinity |
12 Oct 2007: SE J110i, J120i unlock, repair supported, Moto c168, c168i, w220 repair | InfinitySupport | Infinity-Box | 123 | 04-21-2011 07:54 |
Cant unlock Sony-Ericsson-J132 | rajhcl0 | Infinity-Box | 3 | 03-29-2010 18:28 |
Cant Unlock J110i With Infinity. | rajan nishchal | Infinity-Box | 18 | 11-01-2007 21:53 |
another j110i still cant unlock | obioha | Infinity-Box | 1 | 10-08-2007 21:15 |
j110i succefully unlocked | patric | Infinity-Box | 1 | 09-23-2007 12:44 |
