Old 09-29-2007, 11:21   #1 (permalink)
Member: 348451
Thanks Meter: 2
Exclamation sos
i need the n95 slider pinouts plz
i tried every thing but it didn't work
and i even damaged my box twice from the wrong pinouts
would you plz help me and see the pictures
Old 09-29-2007, 11:56   #2 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Here is the pinout.Please post more about connector type
1,5 GND
6 RX
7 TX
12 VCC
This is with the Chinese pin count beginning from the left
Old 09-29-2007, 16:12   #3 (permalink)
Member: 64065
Thanks Meter: 5
1,5 GND
6 RX
7 TX
12 VCC
infinity team this pinout damage box please add corecct pinout
Old 09-29-2007, 16:56   #4 (permalink)
Member: 348451
Thanks Meter: 2
the connector type is 1*12 mini
and about the box i managed to repair it
if someone need help i can do it
Old 09-29-2007, 18:43   #5 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
I asked you because of it.The pinout I posted is for 2*6 connector type.
Old 09-29-2007, 19:05   #6 (permalink)
Member: 64908
Thanks Meter: 9
if u open the fone u wil see 5 pionts on the pcb but the problem is this no mantion which 1 is gnd,tx,rx,+v,pwr
use multimeter and yours brain u can got the pinouts if u have n e problem pm me
Old 09-29-2007, 21:43   #7 (permalink)
Member: 348451
Thanks Meter: 2
the gnd is the first pin and the (+) is the last pin and there is no other gnd pins
i tried every thing and even checked it with the multimeter and i found the pins but no use the box wont read it
what about the vcc or vpp do i have to use it and how?
Old 09-29-2007, 22:26   #8 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
3 unknown pins giving us just 6 possible combinations of tx/rx.
connect box ground pin to phone GND point and try all 6 combinations of tx/rx.
this can be done less than in 5min
Old 09-30-2007, 09:03   #9 (permalink)
Member: 348451
Thanks Meter: 2
am despert
i told that i tried every thing
even i found two pins on the bord it looks like the correct tx/rx
and it's writtin down besides every one of them the rj54tx/rj45rx
and this way worked for alot of phones
but it din'dt work for 10 devices n95
what should i do
should i tell my customers that i can't handle it
Old 09-30-2007, 10:15   #10 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
what should i do
You should better use search instead of saying that I can't handle it
Old 09-30-2007, 10:37   #11 (permalink)
Member: 348451
Thanks Meter: 2
sweety i already told you that i tried every thing
am not lazy but nothing worked thats the fact
Old 09-30-2007, 10:46   #12 (permalink)
matin-gsm's Avatar
Member: 446040
Thanks Meter: 1,065
hey foxi ,
i have the same problem as you ! tested all pinouts but no succed .
if you found some thing share it with me please .
Old 09-30-2007, 19:44   #13 (permalink)
Member: 348451
Thanks Meter: 2
wher is the great support i used to know
am dying here gyus
Old 09-30-2007, 20:30   #14 (permalink)
Member: 130995
Thanks Meter: 35,227
am dying here gyus
The Great Support always here and never tired to give detailed explanation how to solve any of your problems.
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to make detailed description of model,
attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector.
After you have this information prepared, please, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 09-30-2007, 21:53   #15 (permalink)
visualtech's Avatar
Member: 15333
phone bottom connector_1x12_mini
___________________________
/ 1 2 3 4 5 6 7 8 9 10 11 12\
phone pin 1 ground connect to box pin 7 or 8
phone pin 6 tx connect to box pin 3 rx
phone pin 7 rx connect to box pin 2 tx
tested by me working 100%
V3xxv SOS SOS SOS elhadjioumar Motorola P2k 0 07-04-2008 18:44
sos sos sos dvdgsm Nokia Digital Core Technology 4 ( DCT-4 ) 3 12-10-2006 04:53
SOS, sos, sos----help royalassi LG 1 08-22-2004 02:07
2110+3110+5110 need HELP sos sos sos so......... Ashwani Gaur Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-31-2001 12:05
SOS-SOS -URGENTLY NEED S35_0504-SOS-SOS igor_m x1x to x45/x50 2 09-15-2000 01:08
Page generated in 0.30061 seconds with 11 queries
