09-18-2007, 10:56 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: HR Age: 48
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | J120i info COM3 ready COM3 selected Device: Sony-Ericsson J120i Checking data, wait... Action: read eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 032H-000 HW ver: MLD-5- Check Flash Done Check Parameters... file saved: backup_eeprom_calibration_20070918-112900.6AE.bin file saved: backup_eeprom_ffs_20070918-112924.6AF.bin Flash: 0089:886200010001 Finished, time used: 71 sec Remove/Install battery now ! COM3 selected Device: Sony-Ericsson J120i Checking data, wait... Action: read flash Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 032H-000 HW ver: MLD-5- Check Flash Done Check Parameters... part 1 of 1... Reading... error: unexpected rx block size: 001EC3/002000 error: unexpected rx block size: 001D2F/002000 error: unexpected rx block size: 001AB8/002000 file saved: backup_full_part_1_of_1_20070918-113723.6AX.bin Flash: 0089:886200010001 Finished, time used: 409 sec Remove/Install battery now ! Didn't try SP-Unlock after that! Also Just before it started reading, asked me if I want to continue cause probably wrong phone model was selected. It is SE J120i... |
09-20-2007, 13:02 | #6 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 316600 Status: Offline Thanks Meter: 13 | dear infinity COM5 [VCP0] selected Device: Sony-Ericsson J120i Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 032H-000 HW ver: MLD-5- Check Flash Done Check Parameters... file saved: backup_eeprom_calibration_20070920-135950.6AE.bin Check Parameters Done Check Space... Flash: 0089:886200010001 flash: Intel 28F320W18-T T 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Writing Done Finished, time used: 33 sec Remove/Install battery now the phonr rest loked any solution please |
09-20-2007, 13:03 | #7 (permalink) |
Member: 316600 Status: Offline Thanks Meter: 13 | dear infinity COM5 [VCP0] selected Device: Sony-Ericsson J120i Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 032H-000 HW ver: MLD-5- Check Flash Done Check Parameters... file saved: backup_eeprom_calibration_20070920-135950.6AE.bin Check Parameters Done Check Space... Flash: 0089:886200010001 flash: Intel 28F320W18-T T 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Writing Done Finished, time used: 33 sec Remove/Install battery now the phonr still loked any solution please |
09-20-2007, 16:22 | #9 (permalink) |
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | COM3 selected Device: Sony-Ericsson J120i Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 032H-000 HW ver: MLD-5- Check Flash Done Check Parameters... file saved: backup_eeprom_calibration_20070920-171740.6AE.bin Check Parameters Done Check Space... Flash: 0089:886200010001 flash: Intel 28F320W18-T T 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Writing Done Finished, time used: 40 sec Remove/Install battery now ! The same Moto02 v1.44, phone still locked after SP-Unlock! P.S. I am using cruiser K750 cable! |
some usfull BB5- New SL3 Firmware info ... . | dipendra_22 | Nokia Hardware & Hardware Repair | 1 | 12-15-2010 17:30 |
please read this info in n70 | jaleelkuttikkar | Nokia Base Band 5 ( BB-5 ) | 2 | 03-29-2010 16:36 |
SE J120i | nadeem_75 | Infinity-Box | 5 | 07-13-2007 14:17 |
SonyEricsson J120i support? | Abzal | Infinity-Box | 2 | 07-12-2007 10:45 |
Sonyericsson K550i and J120i which box support | bcnboy | Sony Ericsson | 1 | 02-10-2007 15:20 |
