j132 Boot fail Hi, Is there any chance to unlock this version : COM4 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 48 sec Remove/Install battery now ! |
hi try to set baud to 115200 and hold power thx |
Hi, same problem, thanks |
same problem COM49 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: flash write Write: Firmware Skip: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 71 sec Remove/Install battery now ! |
it's a nnew version of j132 with new boot can't be unlocked using all supported tool |
Yes can't be unlocked coz i used 3 tools and without success |
with setool unlock success! v0.915016/UNI CARD SERIAL: 00039171 Loaded 51 flash descriptors PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... FLASH ID: 0020/88C0 (00010000) SECURITY AREA BACKUP CREATED. PHONE IMEI:35710702518169 MODEL:J132 FACTORY CXC:CXC1250616_R5A038 CURRENT CXC:1211-2311_R1AA029 CURRENT CDA:1216-3372_R6A Elapsed: 25 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... FLASH ID: 0020/88C0 (00010000) SECURITY AREA BACKUP CREATED. PHONE IMEI:35710702518169 USERLOCK RESET TO "0000" TOTAL CALL TIME RESET Firmware lock check determined. SIMLOCK PATCH EXECUTED Updating TA... Elapsed: 23 secs. |
keep pressing the power button |
j132 not unlocked by setool but new security Quote:
Hi for all i use the last version v0.915030 here the errors v0.915030/UNI CARD SERIAL: 00078389 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 31 secs. PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 30 secs. PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 14 secs. PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... LOADER NOT RESPONDING failed FAILED TO SETUP PHONE Elapsed: 25 secs. |
Infinity Box >>> Infinity Auto Pin Finder >> >>module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 48 sec Remove/Install battery now ! I can not deal with... |
is there a solution to this |
reply Quote:
post log after please |
