01-30-2009, 08:10 | #1 (permalink) |
Insane Poster Join Date: Dec 2007 Location: Indoa
Member: 647448 Status: Offline Sonork: [email protected] Thanks Meter: 13 | Spice s920 urgent solution IT DOESN'T TAKE ANY FORMAT (COMPLETE & SAFE) NOW TELL ME WHAT TO DO......... MOBILE PCB IS FRESH. I GO TO SUPPORT AREA BUT THERE IS LOWER VERSION FLASH FILE. SO I NEED LATEST FLASH FILE FOR IT. PLEASE POST FLASH FILE OR LINK OF FILE. I HAD THIS VERSION FLASH FILE IN MY PC_____ Spice-S920_D363SP_PCB03_GPRS_MT6228_S02.KAB363_INA_EN_0_ 90_617_64m_En.B4M.bin AND NEED LATEST VERSION(HIGHER VERSION THEN ABOVE) THANKS IN ADVANCE |
01-30-2009, 09:26 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It can not be true that phone become damaged after user code reading. Please, post here honest information what you have tried to do and what was with phone before your operations. |
01-30-2009, 13:55 | #3 (permalink) | |
Member: 647448 Status: Offline Sonork: [email protected] Thanks Meter: 13 | Spice s920 Quote:
SIR MY PHONE WAS WORKING FINE BEFORE I READ CODES. THIS IS INFORMATION OF MY PHONE:: COM21 [VCP0] selected module v2.56 Device: Spice-S920 Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw 1: D363SP_PCB03_GPRS_MT6228_S02.KAB363_INA_EN_0_90_81 5.BIN ver. sw 2: KAB363_INA_EN_0.90.815, 9AAEF89E ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 chip: 0031:0000:0101 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: 20F18015 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 0020:00F100800015 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... reading structure area... detecting structure... source data: page only identification#1 protocol ver: 04 ver. sw 1: D363SP_PCB03_GPRS_MT6228_S02.KAB363_INA_EN_0_90_61 7.BIN ver. sw 2: KAB363_INA_EN_0.90.617, 2F423A8E ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.27EAD FDB.[D363SP_PCB03_GPRS_MT6228_S02.KAB363_INA_EN_0_90_61 7.BIN_71C5BDD0].rpl identification#1 detection finished warning: rpl file not found: C:\Program Files\InfinityBox\MModule\id.27EADFDB.[D363SP_PCB03_GPRS_MT6228_S02.KAB363_INA_EN_0_90_81 5.BIN_61075165].rpl warning: rpl file not found: C:\Program Files\InfinityBox\MModule\id.27EADFDB._D363SP_PCB0 3_GPRS_MT6228_S02.KAB363_INA_EN_0_90_815.BIN_61075 165_.rpl security area (code #1) backup loaded security area (code #1) calculation... Identification Done Write ... file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_27EADFDB_D363SP_PCB03_GPRS_MT6228_S02.KAB363_IN A_EN_0_90_617.BIN_71C5BDD0_20090130-182036.B4X.bin NOW TELL ME WHAT TO DO SIR PLEASE THANKS IN ADVANCE.. | |
01-30-2009, 20:13 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You do not need to flash phone if you want to remove user code, you can just make "read unlock codes" operation that is more than safe. Do you have original full flash backup ? If yes, send it to [email protected] or upload to rapidshare.com If somebody has S900 full flash backup version D363SP_PCB03_GPRS_MT6228_S02.KAB363_INA_EN_0_90_81 5 please, send it to [email protected] or upload to rapidshare.com Also you can try to flash your phone with this file: \flashfiles\Spice\S920\Spice-S920_D363SP_PCB03_GPRS_MT6228_S02.KAB363_INA_EN_0_ 90_617_64m_En.B4M.bin \flashfiles\Zonda\N2000\Zonda-N2000_D363MXC_PCB03_GPRS_MT6228_S02.KAB363_MXA_SP_ FR_EN_0_90_B30_En_Fr_Es.B4M.bin |
01-31-2009, 05:44 | #5 (permalink) | |
Member: 647448 Status: Offline Sonork: [email protected] Thanks Meter: 13 | no solution sir Quote:
S920_D363SP_PCB03_GPRS_MT6228_S02.KAB363_INA_EN_0_ 90_617_64m_En.B4M.bin but my mobile still dead. a had also erased full flash and then re fashed but still mobile is dead.... please post any solution sir..... | |
01-31-2009, 10:46 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, read my message once again: http://forum.gsmhosting.com/vbb/show...77&postcount=4 Please, this time read it more carefully than before. |
01-31-2009, 13:35 | #7 (permalink) | |
Member: 647448 Status: Offline Sonork: [email protected] Thanks Meter: 13 | thanks sir for suppor Quote:
sir thank you very much for your support. i had solved my problem.. many many thanks sir. | |
01-31-2009, 13:41 | #8 (permalink) | |
No Life Poster Join Date: Nov 2006 Age: 44
Member: 388207 Status: Offline Thanks Meter: 221 | Quote:
that's great but don't u think u should give here the the detail how u solved ur problem u have posted ur problem in detail when u got problem now u should be fair enough to share how u solved ur problem out here it may be from ur part that u have missed something while repairing ur phone with infinity we must know i think | |
The Following User Says Thank You to Deepakranasaria For This Useful Post: |
02-01-2009, 06:33 | #9 (permalink) |
Member: 647448 Status: Offline Sonork: [email protected] Thanks Meter: 13 | Ok check it First i erase full flash . Then i flash my mobile with \flashfiles\Zonda\N2000\Zonda-N2000_D363MXC_PCB03_GPRS_MT6228_S02.KAB363_MXA_SP_ FR_EN_0_90_B30_En_Fr_Es.B4M.bin now my problem had been solved. |
The Following 3 Users Say Thank You to surajmobile For This Useful Post: |
02-01-2009, 07:02 | #10 (permalink) | |
thanks for sharing bro if user make it a practice to post how they solved there problemit will help others also thanks for sharing | |
02-01-2009, 16:03 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Also, if somebody can read more good flash files from S920 please, send full flash backup files to [email protected] so we will be able to upload more files for all users. |
Spice S920 Firmware Needed.. | mayank.gupta | Infinity-Box | 1 | 03-24-2010 09:50 |
Spice S920 Firmware Needed.. | Shubhanshu~ | Infinity-Box | 1 | 08-19-2009 19:46 |
Arabic Flash file For KONKA D363 OR Spice S920 ? | .:: Sepid Gsm ::. | Infinity-Box | 0 | 02-15-2008 12:45 |
spice s920 pinouts | tajinder | Infinity-Box | 41 | 10-29-2007 11:50 |
24 Oct 2007: Philips-390, Spice-S920 models supported | InfinitySupport | Infinity-Box | 10 | 10-25-2007 06:08 |
