Old 12-24-2008, 08:49   #1 (permalink)
Member: 695543
Sonork: 100.1602536
Thanks Meter: 149
j132 unlock succesfuly
hi, j132 unlock succefully no need to creat cabel.just used infinty box and used c2500 cabel and also used smart clip 4 using odden series.and conect phone for using infint comport. i unlock two j132 phone by t mobile.
The Following User Says Thank You to some_info2010 For This Useful Post:
Old 12-24-2008, 11:01   #2 (permalink)
Member: 563167
Thanks Meter: 39
COM6 [VCP1] selected
module v1.30
Device: Sony-Ericsson-J132
"advanced chip detection" active
Action: unlock
Checking data, wait...
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 2088C0FFFFFFFF:2088C000000000
flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb
Check hardware done
Read data ...
reading Sony-Ericsson-J132_eeprom_calibration-1...
warning: wrong data size at 0x067F2000, retry...
read error recovered
warning: wrong data size at 0x067F2400, retry...
warning: wrong data size at 0x067F2800, retry...
warning: wrong data size at 0x067F2C00, retry...
warning: wrong data size at 0x067F4400, retry...
warning: wrong data size at 0x067F4800, retry...
warning: wrong data size at 0x067F5400, retry...
warning: wrong data size at 0x067F5800, retry...
warning: wrong data size at 0x067F9000, retry...
warning: wrong data size at 0x067FA800, retry...
warning: wrong data size at 0x067FCC00, retry...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20081224-093354.80E.bin
Read data done
Check data ...
Check data done
Write ...
warning: wrong data size at 0x06141000, retry...
warning: wrong data size at 0x06141C00, retry...
warning: wrong data size at 0x06143800, retry...
Write: simlock
Write done
Finished, time used: 196 sec
Remove/Install battery now !
thxxxxxxxxxx 2 infinity team..
The Following 2 Users Say Thank You to cllins For This Useful Post:
Old 12-24-2008, 19:31   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Old 12-26-2008, 17:53   #4 (permalink)
Member: 695543
Sonork: 100.1602536
Thanks Meter: 149
can u used new version of smart card.its only possibel for that .also if u have pinfinder u can unlock j132 on that .plz check otherwise i upload pic and log file
J132 new security unlock ok...j132 unlock ok with v0.915043 aleem26 SETool2 0 09-07-2009 05:59
l6 unlocked succesfuly without tp tenma Ultima Box Light 1 06-12-2007 23:01
Page generated in 0.16307 seconds with 9 queries
