01-30-2009, 22:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | <<J132 unlocked successfully by infinity box>> Here is unlocking operation log: ==== log: [2009/01/31 12:38:46 ق.ظ] ==== COM4 selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20090131-004003.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 85 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to meisam For This Useful Post: |
01-30-2009, 23:08 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
01-31-2009, 02:26 | #3 (permalink) |
Banned Join Date: Dec 2006 Location: inside of infinity best tool
Member: 411831 Status: Offline Thanks Meter: 215 | but me. COM5 selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... and stop...................... |
01-31-2009, 08:06 | #5 (permalink) |
Freak Poster Join Date: Nov 2008 Age: 43
Member: 904326 Status: Offline Thanks Meter: 62 | COM10 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 49 sec Remove/Install battery now ! what solution |
01-31-2009, 09:30 | #6 (permalink) | |
Member: 115172 Status: Offline Thanks Meter: 212 | Quote:
01-31-2009, 09:40 | #7 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | Quote:
which cable your use for unlocking?????? or unlock with the help of infinity pinfinder?????? | |
01-31-2009, 10:41 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
VK200 unlock success by infinity | jakoy | Infinity-Box | 8 | 03-18-2009 10:09 |
Coral C200 Digicel Locked/ unlocked success by infinity box.. | kingskie | Infinity-Box | 1 | 11-20-2008 04:55 |
<< LG KG 271 Unlocked successfully By Infinity >> | zeel_zeel | Infinity-Box | 1 | 08-07-2008 12:53 |
LG KE970 unlock success by infinity | jakoy | Infinity-Box | 3 | 07-21-2008 16:05 |
J100 Unlock Successfully By Infinity. | debmobile | Infinity-Box | 1 | 07-05-2008 09:58 |
