05-20-2016, 05:17 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | error in mtk Code: Operation : Check / Read Info [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 254 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040503A20A4822B3 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2004 EMICFG_UNKNOWN_ERROR Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! |
05-20-2016, 06:01 | #3 (permalink) |
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | Code: Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 254 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040503A20A4822B3 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2004 EMICFG_UNKNOWN_ERROR Boot Error! Operation Failed Elapsed: 00:00:23 Reconnect Power/Cable! |
05-20-2016, 06:49 | #4 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
05-20-2016, 07:12 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | If phone dead - start from seek correct preloader or FW. That clearly explained in log. |
05-20-2016, 07:25 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | @avtarkaint Just write good firmware to phone. Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
05-20-2016, 13:10 | #7 (permalink) |
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | Operation : Flash [ v1.47 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 254 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040503A20A4822B3 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBF0B0000 EMICFG_RET_FAILED CodeDefine : DA_DRAMC_RANK1_CALIBRATION_FAILED Boot Error! Operation Failed Elapsed: 00:00:30 Reconnect Power/Cable! |
05-20-2016, 16:17 | #9 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
05-20-2016, 16:24 | #10 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Yes hardware fault, got one phone with nearly same error- Quote:
Infinity Box Support Team. | |
10-29-2016, 18:24 | #13 (permalink) |
No Life Poster Join Date: Dec 2005 Location: algeria
Member: 206173 Status: Offline Thanks Meter: 169 | hello everybody i have g530h mtk dead i trryed to flash and i have this error ======= Flash Files set for flashing : [ MCU ] : MTK6572_1408131156.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 57 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A2058494E594816A1662DF2807B Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBE0B0000 EMICFG_RET_FAILED CodeDefine : DA_DRAMC_RANK0_CALIBRATION_FAILED Boot Error! Operation Failed Elapsed: 00:00:37 Reconnect Power/Cable! Operation : Flash [ v1.51 ] ======= Flash Files set for flashing : [ MCU ] : MTK6572_1408131156.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 57 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A2058494E594816A1662DF2807B Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBE0B0000 EMICFG_RET_FAILED CodeDefine : DA_DRAMC_RANK0_CALIBRATION_FAILED Boot Error! Operation Failed Elapsed: 00:04:56 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to yahia ali For This Useful Post: |
11-17-2016, 06:57 | #14 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2009 Location: Marakand
Member: 1163999 Status: Offline Thanks Meter: 97 | Please help me +1 G530H [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBE0B0000 EMICFG_RET_FAILED CodeDefine : DA_DRAMC_RANK0_CALIBRATION_FAILED Boot Error! |
