04-10-2018, 10:50 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, work is in pogress. update will be released as soon as it will be ready. right now you can use current software version with custom DA files, this helps to repair more than 90% of phones. |
The Following User Says Thank You to princesaddam For This Useful Post: |
04-10-2018, 12:59 | #4 (permalink) |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, CUstom Da files u can find in support Area,,just login with ur IOS then see |
04-10-2018, 18:24 | #5 (permalink) | |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Hello Quote:
1° open your own thread and post your operation logs about problem. 2° name model cpu OS version etc... 3° what kind help you need. 4° The most important thing, about update The answer is same for you and all other users "WORK IN PROGRESS" good solution need time.. If you need quick solution use SEARCH button.. Or use DA file and do what you need. | |
The Following User Says Thank You to yuranc8 For This Useful Post: |
