03-04-2016, 12:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | JayDi Please check this Check the colour marked lines Operation : Read Flash [ v1.42 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6795 BB_CPU_NME : [MediaTek] Helio[X10]|MT6795_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x92 NAND Flash : NOT INSTALLED eMMC Flash : 15010042474E443352013401B62A1207 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R3DNG [eMMC] : FLASH_CID : 15010042474E443352013401B62A1207 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 31EF0201B5C3D38F07174E643E31D9C5 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! [Read Ok] : preloader_htc_a55ml.bin [Read Ok] : persist.img [Read Ok] : lk.bin [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : hosd.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : sensor_hub.img [Read Ok] : carrier.img [Read Ok] : apppreload.img [Read Ok] : cota.img [Make Ok] : cache.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Make Ok] : userdata.img [ScatCFG] : MT6795 / V1.1.2 / htc_a55ml / EMMC Android Info saved HWConfig Info saved FW Size : 5198 MiB Scatter saved to : C:\Documents and Settings\Administrator\Desktop\MT6795______\ All done! |
The Following User Says Thank You to srinibas For This Useful Post: |
03-04-2016, 13:26 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. I just updated stuff to support them, but not had a sample to check it completely. It have quite big size. Which model it exactly? If you try pack file - what size will be? Can you send it after? |
03-04-2016, 13:39 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Not should be so much. I have 64 GiB phone with 1.6 GiB size. It not a criteria. HTC uses own subsystems to store relevant, debug, special and security data. Also CUSTOMIZATION part take much, but I prefer check all, to make sure on result. |
03-04-2016, 14:07 | #6 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
After compress it is little higher 2GiB I will upload soon Br - srinibas | |
