08-24-2017, 22:25 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: kapurthala punjab
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | OPPO A37f Vibration Only DEAD RECOVER DONE WITH CM2 Device Brand : OPPO Device Manufact.: OPPO Device Model : A37f Device CPU : MSM8916 Device IntName : A37f Device Version : 5.1.1 SWVersion : A37fEX_11.A.20_INT_020_201705061419 CU_SWVer : OPPO Device Compile : 5/6/2017 8:08:20 AM Device ExtInfo : A37f Load Ok! Operation : Flash [ v1.15 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.15 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.15 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.15 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 245F9345 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 42A2D826911D0A05E257B9A66138B890 ID_BLOCK_L : 3A49F7565BCA74F114E3B46D678E98A3 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 43 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sec.dat Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : lsplash.img Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cache.img Flashing : persist.img Flashing : misc.img Flashing : driver.iso Flashing : userdata.img Flashing : gpt_backup0.bin Flashing : gpt_main2.bin Flashing : cdt.mbn Flashing : gpt_backup2.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:12:39 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to sachu2002 For This Useful Post: |
08-25-2017, 07:34 | #3 (permalink) | |
Insane Poster Join Date: Mar 2016
Member: 2543662 Status: Offline Thanks Meter: 395 | Quote:
Sent from my XT1068 using Tapatalk | |
The Following 2 Users Say Thank You to md.sufyan For This Useful Post: |
08-25-2017, 07:55 | #4 (permalink) | |
No Life Poster Join Date: Mar 2011 Location: FIND ME Age: 32
Member: 1538904 Status: Offline Sonork: 100.1603095 Thanks Meter: 198 | Quote:
The Following 4 Users Say Thank You to uniontelecom For This Useful Post: |
08-29-2017, 17:29 | #8 (permalink) |
Freak Poster Join Date: Jun 2011 Location: AGRA
Member: 1599892 Status: Offline Sonork: 100.1612224 Thanks Meter: 47 | U have to change Qualcomm Hs-USb Loader 9008 to Care Suite Emergency Port. Then Infinity Detect all Qualcomm Cpu. |
The Following 2 Users Say Thank You to mintushakya For This Useful Post: |
12-04-2017, 18:14 | #9 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2152730 Status: Offline Thanks Meter: 4 | Oppo A37fw/f 100% tested dead solution. firmware and password in vodeo's discription. http://gestyy.com/wuUmf8 https://*********/KRYfmNmvlYs enjoy |
The Following 2 Users Say Thank You to aditya111184 For This Useful Post: |
