12-18-2015, 16:56 | #1 (permalink) |
No Life Poster Join Date: May 2013 Location: UFI-BOX+EASYJTAG BOX Age: 34
Member: 1934602 Status: Offline Sonork: 100.1649323 Thanks Meter: 482 | Jaydi Sir Answred....... Readed Sucsess......... Operation : Read FullFlash [ v1.08 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : Primo_D6 Model Brand : WALTON Model Device: Primo_D6 AndrVersion : 4.4.2 BaseBand CPU: WALTON Project Ver : KOT49H 14B_release-keys Model Ext : Primo D6 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem.bin [Read Ok] : sc8830g_modem_CP2_WCN_14D_W15.34.1_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img Firmware Size : 1139 MiB Saved to : C:\Users\TaHa_MoNi\Desktop\WALTON_Primo_D6_4.4.2_K OT49H_14B_release-keys\ Done! Elapsed: 00:10:52 Reconnect Power/Cable! |
12-18-2015, 17:05 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | 1. Press "PAC" button on file selection. 2. In opened window select "File Filter" to "pac.sc" 3. Go to FW folder, there is folder "Infinity" and one files - SC77xx_FLASH_CONF.pac.sc 4. Select file Press "Flash" button. |
12-18-2015, 17:37 | #3 (permalink) |
Member: 1934602 Status: Offline Sonork: 100.1649323 Thanks Meter: 482 | Thanks Jaydi Sir ,Problem Solove........ Operation : Flash [ v1.08 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Flash [ v1.08 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.34.1_Release.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : logo_480x800.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x800.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Process : Flush Flush Ok! Write FSImage : userdata.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Elapsed: 00:04:17 Reconnect Power/Cable! |
12-19-2015, 05:00 | #5 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
http://forum.gsmhosting.com/vbb/11485198-post4.html | |
