11-17-2017, 21:41 | #1 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Huawei TIT-U02 (Y 6 Pro) Boot Done ! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4841473265050751D3AA5F23CD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050751D3AA5F23CD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xF0C858A3C7C62D7A9482C21B460CEE5C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : HUAWEI ProdName : TIT-U02 ProdModel : HUAWEI TIT-U02 Device : HWTIT-U6582 AndroidVer: 5.1 MTKxCPU : MT6582 MTKxPRJ : ALPS.L1.MP12.V1_ONTIM6582.WE.L1_P59 SECURITY : IMEI_SW [1] : 86XXXXXXXXXXXXX IMEI_SW [2] : 86XXXXXXXXXXXXX BTMAC Addr : BXXXXXXXXXXX WiFi MAC : BCXXXXXXXXXX MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1449_MD_WG_MP_V29_5_P1_1_wg_n EXTRA : LCD [0] : r61318_hd720_dsi_vdo LCD [1] : otm1287a_hd720_dsi_vdo_tianma LCD [2] : otm1287a_hd720_dsi_vdo_boyi LCD Res : 1280x720 TOUCH [0] : GT9XX CAM [0] : ov13850OF_mipi_raw CAM [1] : ov5670OF_mipi_raw CAM [2] : ov13850QT_mipi_raw CAM [3] : ov5670SE_mipi_raw MODEM : ontim6582_we_l1_hspa ontim6582_we_l1_gprs LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:07 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Pijush Das For This Useful Post: |
11-17-2017, 22:29 | #3 (permalink) |
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Here is Your Log Sir... Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4841473265050751D3AA5F23CD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050751D3AA5F23CD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xF0C858A3C7C62D7A9482C21B460CEE5C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : HUAWEI ProdName : TIT-U02 ProdModel : HUAWEI TIT-U02 Device : HWTIT-U6582 AndroidVer: 5.1 MTKxCPU : MT6582 MTKxPRJ : ALPS.L1.MP12.V1_ONTIM6582.WE.L1_P59 [Read Ok] : preloader_tit-u02.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : EBR3 [Read Ok] : custom.img [Read Ok] : nfflog.img [Read Ok] : bak.img [Read Ok] : simlock.img [Read Ok] : deviceslog.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / tit-u02 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2375 MiB Scatter saved to : C:\Users\BOSS\Desktop\By Pijush\MT6582__HUAWEI__HUAWEI_TIT-U02__HWTIT-U6582__5.1__ALPS.L1.MP12.V1_ONTIM6582.WE.L1_P59\ All done! Done! Elapsed: 00:13:54 Reconnect Power/Cable! |
The Following User Says Thank You to Pijush Das For This Useful Post: |
11-20-2017, 07:46 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
