Old 04-20-2017, 12:41   #1 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
panasonic p55 dead after flash
Card found : S/N : 0D63E285 , v0135
Scatter Load Ok , BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC
Files found : 13 , Set to Flash : 12
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : Panasonic
Device Model : P55
Device CPU : MT6589
Device IntName : P55
Device Version : 4.4.2
Device Compile : 7/2/2014 1:07:31 PM
Device Project : ALPS.KK1.MP5.V1.5
Device ExtInfo : Panasonic P55
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 209 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BB_CPU_NME : [MediaTek] MT6583|6589_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x86
NAND Flash : NOT INSTALLED
eMMC Flash : 484A019064314734A208050441C14078
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040508A27840C141
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x7535D697CAD0EF6B1742A089A45196B5
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3529 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000880000-0x0000000000100000
Erase : 0x00000000029A0000-0x0000000048960000
Flash Pre-Erase Done, time used : 00:00:02
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0016
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : AUTOBAK
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:04:27
Processing : Verify
Verify Error! Something went wrong!
ErrCode : 0x00FF
Operation Failed
Elapsed: 00:04:49
Reconnect Power/Cable!
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Info read not done Erased/damaged phone?
Done!
Elapsed: 00:00:11
Operation : HW Test [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Initial info read error! Erased or damaged FlashIC?!
Force eMMC test by user request
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB
[eMMC] : CID : 90014A4834473164040508A27840C141
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
All Done!
Done!
Elapsed: 00:00:44
Old 04-20-2017, 13:49   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Reflash device normally. Charge battery. Read logs sometimes.
Old 04-20-2017, 16:39   #3 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
Use sp flashtool to flash
Old 04-21-2017, 04:10   #4 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
problem solved by og tool
The Following User Says Thank You to umarmsn For This Useful Post:
Old 11-17-2017, 08:16   #5 (permalink)
Member: 676845
Sonork: 100.1603282
Thanks Meter: 31
which tool u use to recover ??
my phone not detect in ygdp but flash with inferno and p flash tool but does not power on ... before flash android restart problem,, now dead
Old 11-17-2017, 08:20   #6 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
your back lable screen shot pls
when i pan set dead itendify is detected model so i can recovery easy do first idendityfy
Old 11-17-2017, 08:23   #7 (permalink)
Member: 676845
Sonork: 100.1603282
Thanks Meter: 31
panasonic p55
model no. EB-90S055P55
H/W : EB- 90S055P55 volt1
s/w : EB -90S055P55 v1015
Old 11-17-2017, 10:47   #8 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
panasonic p55
Hello,
Make HW Test, if FlashIC ok then flash with THIS file.
Br.
Infinity Box Team.
Old 11-17-2017, 11:44   #9 (permalink)
Member: 676845
Sonork: 100.1603282
Thanks Meter: 31
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
Infinity Box Team.
Are u sure it is p55 file ?
i think its p55 nova file
Old 11-17-2017, 12:20   #10 (permalink)
Member: 676845
Sonork: 100.1603282
Thanks Meter: 31
Hello,
Br.
Infinity Box Team.
its mtk 6735 file!!
i need p55 mtk 6589
Old 11-17-2017, 12:55   #11 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
its mtk 6735 file!!
i need p55 mtk 6589
Hello,
Hardware P3- https://drive.google.com/open?id=0B7...UNuQ3dNWHQ2Q3c
Hardware P1- https://drive.google.com/open?id=0B7...1VnOTZ4SmFCTDg
Br.
Infinity Box Team.
Old 11-17-2017, 13:09   #12 (permalink)
Member: 676845
Sonork: 100.1603282
Thanks Meter: 31
try both file but set dead
Old 11-17-2017, 13:26   #13 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Post flashing log and make read extended info and post log now.
Br.
Infinity Box Team.
Old 11-20-2017, 07:38   #14 (permalink)
Member: 676845
Sonork: 100.1603282
Thanks Meter: 31
sorry sir but i have no infinity box , i have volcano inferno .. can i post inferno read info???
Page generated in 0.20268 seconds with 8 queries
