Old 02-05-2009, 17:22   #1 (permalink)
Member: 519797
Thanks Meter: 6
"JAZZ"Mobile T161L unlock Done
Jast SP-Unlock
All Sim Work 1000000%
COM5 [VCP0] selected
module v1.60
Device: Huawei-T161L
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090205-203903.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090205-203905.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090205-203911.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090205-203930.B1E.bin
backup critical area Done
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 65 sec
Remove/Install battery now !
thanks infinity team
The Following User Says Thank You to Mjabbar For This Useful Post:
Old 02-05-2009, 18:13   #2 (permalink)
Member: 243881
Thanks Meter: 68
bro i need pinout "JAZZ"Mobile T161L
Old 02-05-2009, 18:20   #3 (permalink)
Member: 289888
Thanks Meter: 59
Bro but old post
ok no prob kep it up
Old 02-05-2009, 18:22   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 02-06-2009, 15:57   #5 (permalink)
Member: 243881
Thanks Meter: 68
thanx for reply all the best Infinity-Box
Old 02-06-2009, 21:03   #6 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
dear to unlock use LG c2500 cable for this Jazz T161L mobile.
The Following User Says Thank You to khadim100 For This Useful Post:
Huawei-T161L UNLOCK DONE WITH LG-KG195 CABLE. sajidashraf Infinity-Box 5 06-24-2010 06:50
Huawei-T161L unlock done with infinity imran_hasham007 Infinity-Box 2 05-05-2009 17:36
huawei t161l unlock done nadim electro Infinity-Box 1 03-03-2009 17:04
zong t161L unlock done gsm-world Infinity-Box 1 01-29-2009 10:09
huawei t161l unlock done nadim electro Infinity-Box 2 01-28-2009 13:50
Page generated in 0.16519 seconds with 9 queries
