01-15-2009, 09:08 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Jazz T161L unlocked successfuly module v1.60 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090115-123006.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090115-123007.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090115-123014.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090115-123033.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 67 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to murtaza_nns For This Useful Post: |
01-28-2009, 11:11 | #3 (permalink) |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | ==== log: [1/28/2009 10:25:50 AM] ==== COM53 [VCP0] selected module v1.60 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090128-102616.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090128-102617.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090128-102623.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090128-102643.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 73 sec Remove/Install battery now ! |
01-28-2009, 11:12 | #4 (permalink) |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | ==== log: [1/28/2009 2:58:24 PM] ==== COM53 [VCP0] selected module v1.60 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090128-145842.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090128-145843.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090128-145850.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090128-145909.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 66 sec Remove/Install battery now ! |
The Following User Says Thank You to murtaza_nns For This Useful Post: |
02-07-2009, 16:31 | #8 (permalink) |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | ==== log opened: [2/7/2009 10:56:33 AM] ==== Application: D:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.60 S/N: 3741:0112 Wait... ==== log opened: [2/7/2009 10:57:17 AM] ==== Application: D:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.60 S/N: 3741:0112 Wait... Device: Huawei-T161L Ready ==== log: [2/7/2009 10:57:55 AM] ==== COM17 [VCP0] selected module v1.60 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090207-105812.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090207-105814.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090207-105820.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090207-105839.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 64 sec Remove/Install battery now ! |
02-07-2009, 16:33 | #9 (permalink) |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | ==== log opened: [2/7/2009 6:14:51 PM] ==== Application: D:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.60 S/N: 3741:0112 Wait... Device: Huawei-T161L Ready ==== log: [2/7/2009 6:15:26 PM] ==== COM17 [VCP0] selected module v1.60 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090207-181544.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090207-181545.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090207-181551.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090207-181610.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 65 sec Remove/Install battery now ! |
02-14-2009, 09:05 | #10 (permalink) |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | COM24 [VCP0] selected module v1.61 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090214-130431.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090214-130432.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090214-130439.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090214-130458.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 70 sec Remove/Install battery now ! |
jazz t161l Successfully Unlocked/repaired Phones By infinity box | honey_bbc2001 | Chinese Models & Cloned Phones | 0 | 07-07-2009 07:23 |
Jazz (Mobilink) Huwai T161L Unlock! | msashami | Infinity-Box | 3 | 01-31-2009 17:14 |
Unlock jazz t161l by infinty | SOHAIL BASHARAT | Infinity-Box | 4 | 01-31-2009 11:41 |
Huawei T161L unlocked successfuly (Jazz Mobilink) | GSM-DOCTOR | Infinity-Box | 9 | 01-21-2009 19:51 |
PACO DE JAZZ FROM Unlock easy BIG cheater | samigsm78 | Listed Cheaters | 29 | 10-02-2008 07:49 |
