06-11-2009, 21:10 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please post connector type. are you sure that this is mt62xx MCU based phone? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
08-24-2009, 19:15 | #3 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1100940 Status: Offline Thanks Meter: 1 | I need the same thing. I think it is mt62xx based phone, I typed in *#0044# and the language is set to english. The problem is that I dont know connector type... Here are some pictures if you can see what connector it is... http://img4.imageshack.us/img4/8751/mp2usbv2.jpg http://img6.imageshack.us/img6/9204/mp2usb.jpg |
08-26-2009, 15:45 | #6 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
i had been solved the pb by cable 1x12.. and pinout.. software version: 1.06 cable type: 1x12 (L12C) platform: MT6205, MT6217-MT6228 searching adapter at COM18... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 CPU: MT6225 result: Rx:7 Tx:6 time required: 39 sec Power On ! w.b.r. | |
08-27-2009, 20:57 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this is easy: 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached, phone powered On) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
09-01-2009, 00:49 | #9 (permalink) |
Member: 1100940 Status: Offline Thanks Meter: 1 | dmn, i cant test them because the pins are too small, and too dense. (to close to each other). I've put a needle on the top of the probe, and still its too wide. i can't see if I'm testing one pin or is the needle touching two pins, nor I can count the number of the pin... |
09-02-2009, 11:23 | #11 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
if phone is mt62xx CPU based or not you can check by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is mt62xx | |
09-05-2009, 15:16 | #12 (permalink) |
Member: 1100940 Status: Offline Thanks Meter: 1 | Yes, I have typed in *#0044# and the language is set to english. But is there a way to find OS information. I think it is Nucleus RTOS based phone, but i'm not shure. And does anybody know some more detailed info about writing programs for Nucleus? |
i want E66 UFC pinout | abdurrahimsagar | Nokia Hardware & Hardware Repair | 2 | 05-27-2010 20:37 |
Pinouts for Wi-Fi Mobile C5000 | Stoyan | Infinity-Box | 3 | 04-01-2010 06:06 |
CD player pinout 1J0 035 119c | attilaa0 | CAR Electronics | 4 | 03-30-2010 07:16 |
need pinout sigmatel fxd 3600 | bassemzini | Infinity-Box | 0 | 03-29-2010 19:22 |
JFS N5000 phone | Valdyr | Chinese Models & Cloned Phones | 7 | 08-21-2009 20:23 |
