01-18-2010, 14:56 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Roumania
Member: 461923 Status: Offline Thanks Meter: 2,020 | Jincen JC35 - not allowet to dial -i have this Jincen JC35 dual sim (connector like Samsung d800) -i can't make calls - "not allowet to dial" -after Full factory reset (from menu) still same problem any solutions ?? Thank's |
01-20-2010, 10:55 | #3 (permalink) |
Member: 461923 Status: Offline Thanks Meter: 2,020 | ..problem solved in this way ..: 01. Make sure two SIMs are online with good coverage, WLAN switched off. 02. Press the “call”-button and type in *#3646633# 03. The phone shows “Engineer mode” with a menu of 10 different items. 04. Go to No. 10 “RF test tool”, using the up/down button at the left side of the mobile. 05. Choose “GSM” 06. A message shows up “Wifi….blabla”, just confirm with OK 07. Choose “Power Scan” 08. Select your local GSM frequency (an eisai Cosmote bale GSM900) and press OK. 09. The mobile will freeze now, because its adjusting itself. Leave it like this for about 2-3 minutes and wait !!! 10. Connect your mobile via USB cable to a PC, DO NOT CONFIRM any connection mode at your mobile, just and ONLY connect the cable!!! 11. Press the Menu button (second from the left, the one with the seven small dots on it) until you you the main menu with the 12 icons on the display. 12. Go to “Settings” –> “Network Setup” –> “SIM1 network setup” 13. Go to “Preferred mode” and choose “GSM preferred” 14. The mobile will switch to your selection, but the message that it will stay on display. Do not press anything else, just wait for about 10 – 15 seconds. 15. Disconnect the USB cable from the phone, it will show you that it has switched to your selection. 16. Get back to main menu, switch off and restart the mobile –> DONE. |
01-20-2010, 13:42 | #4 (permalink) | |
Junior Member Join Date: Jan 2006
Member: 220305 Status: Offline Thanks Meter: 0 | Quote:
(meta tous arithmoys ti patas gia na soy diksi to Engineer mode) | |
01-22-2010, 10:34 | #8 (permalink) |
Member: 220305 Status: Offline Thanks Meter: 0 | Hello, I have the JINCEN JC35 from ebay http://cgi.ebay.com/Dual-sim-Mini-WI...item3ca8a88e4a Last edited by savnik; 01-22-2010 at 10:42. |
01-22-2010, 22:28 | #11 (permalink) |
Member: 220305 Status: Offline Thanks Meter: 0 | And these *#900# - BT Local Test *#901# - BT Local Test 1 *#931# - BT_PTS_SIMAP_Graceful_Disc_Type *#932# - BT_PTS_SIMAP_Immediate_Disc_Type *#933# - BT_PTS_SIMAP_PRS But i don't what mean |
01-23-2010, 08:21 | #12 (permalink) | |
Member: 461923 Status: Offline Thanks Meter: 2,020 | Quote:
Need Help Please I am having the “not allowed to dial” problem. ON XG model: A809 (MT | callmeX | Chinese Models & Cloned Phones | 4 | 05-04-2010 20:04 |
JINCEN JC35 Quad Band Dual Card Dual Cameras WiFi Color TV Bluetooth Java 2.8-Inch To | IPMART | ipmart WebShop | 0 | 03-02-2010 13:30 |
Cesim A9530 - Not Allowed To Dial Problem | macsurf | Chinese Models & Cloned Phones | 16 | 12-29-2009 15:14 |
