08-24-2010, 19:55 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | jing ling y88 power E706_XZY1IPHONE_PCB01_GPRS_MT6235B_S01.01_0__firmw are_20100128-144343.B4M this is my firmware |
08-25-2010, 16:17 | #4 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | My log thanks COM3 [VCP0] selected module v3.20 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware E706_XZY1IPHONE_PCB01_GPRS_MT6235B_S01.01_0__firmw are_20100128-144343.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: E706_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 03000000/01000000 firmware size: 48Mb ffs size: 16Mb detect sec ro... detect custom parameters... detect project-id... project-id: E706_XZY1IPHONE.01.0 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: E706_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 05 sw version: E706_XZY1IPHONE_PCB01_GPRS_MT6235B_S01.01_0.BIN project-id: E706_XZY1IPHONE.01.0, 00000000 code offset: 00000000 ffs offset/size [01]: 03000000/01000000 rom info structure: 2nd [standard] type TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: E706_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection finished: Ok startup code area #1 check... error: done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 9 min 39 sec Remove/Install battery now ! |
08-25-2010, 17:34 | #5 (permalink) | |
Freak Poster Join Date: Jan 2009
Member: 950629 Status: Offline Thanks Meter: 105 | Quote:
startup code area #1 check... error: done I think you must full flash the phone with security area fixing. | |
The Following User Says Thank You to mswmkm For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
5110, powers on only with charger conected !!! | mr_x4you | Nokia Hardware & Hardware Repair | 2 | 12-23-2001 19:31 |
Transmitter output power | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-17-2001 23:02 |
8810 power off | Fahlstrom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-08-2001 13:59 |
need advice on 8810 headset/power down problem | goof | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-24-2001 20:56 |
