Old 11-18-2008, 11:51   #1 (permalink)
petermov's Avatar
Member: 79485
Thanks Meter: 47
Confused flashing alcatel c701
Hi all!!! after trying to unlock with other tool an alcatel c701 it crashed, now phone is like a freezed mode, when I try to flash i can mark checkbox firmware, language and fss (I suposed is eeprom) but only one file (firmware) is aviable on support, must I select firmawere file too when marking language and fss flashing options????
A bit confused abaout procedure with infinity tool.
Thanks for your help.
Old 11-18-2008, 12:28   #2 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
Thanks Meter: 905
no, you cant select a firmware file for language or eeprom so
try to reflash the phone with the main firmware file only BUT make a full flash back up and read eeprom just in case
good luck
shehab
Old 11-18-2008, 15:45   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
You need to use only one firmware file.
Here is instruction from support area:
Date: 02 Feb 2008
How to unlock and flash Alcatel-c700, c701, c707, c717, c825 etc.
How to flash:
1. Make full flash backup before any operation for emergency case !
2. Select firmware that you want and write flash
3. If phone can't power-on after flashing flash it again:
. be sure that "Smart write option is checked in "Flash" page
. be sure that "Fix security area" option is checked in "Settings" page
. be sure that "Enhanced security fix method" option is checked in "Settings" page
4. If phone can't Oower-On make "Format ffs" in "complete" mode
5. Press and hold phone "Power" button for a long time (up to 1-2 min) to make phone Powered-On after flash/format
After flash process: Power-On and Power-Off phone 4-5 times to be sure that everything is Ok.
If software say that new firmware detected please make this:
1. read full flash
2. send "backup_flash..." and "backup_system_log..." files to [email protected] or upload to rapidshare.com and send link
How to unlock:
1. Flash phone with non-locked firmware
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 11-21-2008, 17:07   #4 (permalink)
Member: 520764
Thanks Meter: 27
usb flashing
is there a way to flash this phone via it's own usb conection.?
Old 11-21-2008, 17:19   #5 (permalink)
Member: 130995
Hello,
You must use RX/TX/GND cable but not USB cable from phone package.
Alcatel c701 flashe sucssufuullll::ENJOY::: redouane2007 PolarBox 3 0 12-18-2008 14:47
alcatel C701 dead after flash leroi Infinity-Box 8 08-06-2008 12:13
Alcatel C701 Flash /Unlock Successfully MalcomŪ PolarBox 3 17 02-07-2008 18:45
**** Alcatel C701 flashing **** snsoftkiller Alcatel O.T.U.F 0 12-31-2007 20:12
Alcatel C701 unlock/flash solution Nippo Multi-Box 1 12-13-2007 09:42
Page generated in 0.21397 seconds with 9 queries
