11-03-2017, 08:12 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | JIO PHONE keypad 4G flash file read done !! Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 0CF4CC0A ID_BLOCK_I : 000940E1 ID_BLOCK_L : 433FB9FD703B2CA2C1A1B79D89E61E75 ID_BLOCK_L : 019044CFD23A4A156A1E21D221C1B0C5 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000000E2000000 [ eMMC 4 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : LYF ProdName : F90M ProdModel : F90M Device : msm8909_512 AndroidVer: 6.0.1 Manufact. : LYF QLMxCPU : MSM8909 DevInfo : MSM8909__LYF__LYF__ANDR_v6.0.1__F90M__msm8909_512__F90M Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : misc.img [Read Ok] : splash.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : usbdisk.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 1393 MiB Done! Elapsed: 00:02:47 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to sneha For This Useful Post: |
11-03-2017, 11:25 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Der Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool |
11-03-2017, 14:01 | #4 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | Quote:
11-03-2017, 14:34 | #5 (permalink) | |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
File: K:\LYF\FM90 MSM8909__LYF__LYF__ANDR_v6.0.1__F90M__msm8909_512_ _F90M.7z Authentication... Initialization... 03-Nov-17: 6:54:30 PM: Upload... 03-Nov-17: 6:54:30 PM: Operation failed: Already connected. its stuck at nearly 95% from last half n hour | |
11-03-2017, 14:39 | #7 (permalink) | |
Operation: Upload File: K:\LYF\FM90 MSM8909__LYF__LYF__ANDR_v6.0.1__F90M__msm8909_512_ _F90M.7z Authentication... Initialization... 03-Nov-17: 7:05:45 PM: Upload... 03-Nov-17: 7:05:52 PM: Uploading 10,792,179 bytes... 03-Nov-17: 7:07:53 PM: Finished | |
The Following 4 Users Say Thank You to sneha For This Useful Post: |
12-14-2017, 10:00 | #12 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Miracle Box Is BEST
Member: 1158378 Status: Offline Thanks Meter: 23 | Card found : , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 0D87CAFF ID_BLOCK_I : 000940E1 ID_BLOCK_L : 582AACE665202199DAACA0A884ED156E ID_BLOCK_L : EC07B32245D7D9B8FFE1B441B2344D50 Use CM2 Internal Loader Error : Prepare target failed! Unsupported yet CPU! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 0D87CAFF ID_BLOCK_I : 000940E1 ID_BLOCK_L : 582AACE665202199DAACA0A884ED156E ID_BLOCK_L : EC07B32245D7D9B8FFE1B441B2344D50 Use CM2 Internal Loader Error : Prepare target failed! Unsupported yet CPU! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 0D87CAFF ID_BLOCK_I : 000940E1 ID_BLOCK_L : 582AACE665202199DAACA0A884ED156E ID_BLOCK_L : EC07B32245D7D9B8FFE1B441B2344D50 Use CM2 Internal Loader Error : Prepare target failed! Unsupported yet CPU! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
12-14-2017, 10:21 | #13 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Download file frm support,, select file then try and post result | |
