01-07-2016, 20:30 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Just For Fun : Latest 4G Spreadtrum CPU and CM2SPD ;) Code: Operation : Read FullFlash [ v1.12 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 90 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC A4.x Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 90 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC A4.x Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : A2800 Model Brand : Lenovo Model Device: A2800-d AndrVersion : 4.4.4 BaseBand CPU: SP9630EA Project Ver : A2800-d_S300_141118_CMCC Model Ext : Lenovo A2800-d [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : nvitem_tl.bin [Read Ok] : sharkl_cp1.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : pm_sys.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img Firmware Size : 744 MiB Saved to : E:\SP9630EA_A2800-d_4.4.4_A2800-d_S300_141118_CMCC\ Done! Elapsed: 00:09:13 Reconnect Power/Cable! Code: Infinity SC Firmware Detected FW Size : 744 MiB Load Ok! Operation : Flash [ v1.12 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 90 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC A4.x Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x14 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sharkl_cp1.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : pm_sys.bin Write Data ... Write Data Ok! Write CodeData : logo_480x800.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x800.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Process : Flush Flush Ok! Write FSImage : userdata.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Elapsed: 00:03:00 Reconnect Power/Cable! |
The Following 15 Users Say Thank You to JayDi For This Useful Post: |
01-07-2016, 21:44 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Identify : Code: Operation : Check/Read Info [ v1.12 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC A4.x Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : A2800 Model Brand : Lenovo Model Device: A2800-d AndrVersion : 4.4.4 BaseBand CPU: SP9630EA CompileDate : 1429755268 Project Ver : A2800-d_S300_141118_CMCC Model Ext : Lenovo A2800-d ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:17 Reconnect Power/Cable! Code: Operation : Check/Read Info [ v1.12 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 36 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_W15.9.6_Debug Project : sharkl_cp1 HWInfo : sc9630_modem Compile : 04-22-2015 18:38:02 Phone Security Info : IMEI [1] : 866475028662036 IMEI [2] : 866475028662036 BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.591 V Done Reconnect Power/Cable! |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
01-07-2016, 21:45 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Read PatternLock : Code: Operation : Read PatternLock [ v1.12 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC A4.x Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! FlashMode Set : Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 12478569 Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
01-07-2016, 21:45 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Recover PhoneBook : Code: Operation : Read PhoneBook [ v1.12 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC A4.x Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Mount : /data Size : 0x00000000AFDFB000 Step #1 Step #2 Read Ok, PhoneBook records extracted : 9 TXT Saved to : C:\InfinityBox\CM2SPD\phdata\SPD2_PhoneBook.txt Write : 9 CSV Saved to : C:\InfinityBox\CM2SPD\phdata\SPD2_PhoneBook.csv Write : 9 VCF Saved to : C:\InfinityBox\CM2SPD\phdata\SPD2_PhoneBook.vcf Write : 9 VCFv3 Saved to : C:\InfinityBox\CM2SPD\phdata\SPD2_PhoneBook_v3.vcf Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
01-07-2016, 21:46 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Format FS/Reset Settings : Code: Operation : Format File System [ v1.12 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC A4.x Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000000AFDFB000 State : 0x0001 Mount : /cache Size : 0x0000000008C00000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
The Following 10 Users Say Thank You to JayDi For This Useful Post: |
