02-10-2008, 13:03 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: INDIA-uttranchal-rishikesh Age: 47
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | k110 imei is 00000 problrm.......... 1- i did backup eeprom 2- write imei to phone imei 3- reset setting but imei is show me 00000 any good idea for i write imei to phone its too big problem for kg 110 problem can u infinity good solution for this problem... ...... the ant..... |
02-10-2008, 14:53 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Could you, please, tell me what was the reason that imei become zero. I am quite interesting to know this phone history. Also it's not bad idea to post here logs (f.e. imei write operation) |
02-10-2008, 16:08 | #3 (permalink) | |
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | Quote:
backup_404-XX V10d 91 KG110P40FL_eeprom-ffs_352691019817063_LG KG110_LG KG110_20080210-035016.B1E I FACE 50 SET KG 11O ALL OF SAME PROBLEM....... THE ANT.... | |
02-10-2008, 20:09 | #5 (permalink) |
Freak Poster Join Date: Feb 2006 Location: India
Member: 232566 Status: Offline Thanks Meter: 150 | Well i had the same problem with few handsets but i solved it.I used other tool i.e FG.In few seconds it did it,it worked like charm. About the history of this imei corrupted handsets are,customer says till some time i was able to make call but now i am aint.actually when imei gets to 00000, calls cannnot be made. Wbr, |
02-10-2008, 20:32 | #6 (permalink) |
Freak Poster Join Date: May 2006
Member: 281925 Status: Offline Sonork: 100.113915 Thanks Meter: 63 | @all serch before post http:///vbb/showth...93#post3040793 allready have lot of disscustion links @InfinitySupport pls make an sticky post here bcoz u allredy said http:///vbb/showpo...29&postcount=9 |
02-10-2008, 22:19 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @Moderate Why you did not post here detailed explanation what you have tried to do, what was the problem instead of write that you have used other tool and it worked good ? If you can't give any real confirmation that you really have done phone with the same kind of damage like described in this thread it's better to be silent. |
02-12-2008, 19:54 | #9 (permalink) | |
Member: 232566 Status: Offline Thanks Meter: 150 | Quote:
I Tried all functions, i mean i flashed with more than one firmware then repair IMEI,uploaded Eeporms,tried to do reset settings Rebuild IMEI, almost all the functions infact i used old and the last LG application versions,but it sucked a lot and so finally i had to go for the Best tool for LG i.e FG. This is what i did.i am not the only one who had this problem with IMEI 00000,i didint posted cause i had the FG.Well about the 00000 now u can find so many threads. I cant be silent if anything is said against me.I know that,infact there are so many people who knows that infinity doest repair the 00000 IMEI.Only Fg does at the Moment. I have nothing to take anything personal,but u asked me to keep silent which is said against me. Reagrds, | |
02-12-2008, 20:47 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @Moderate I can just repeat my previous words because it's always good idea to make detailed technical information instead of write only words... Why you did not post here detailed explanation what you have tried to do, what was the problem instead of write that you have used other tool and it worked good ? If you can't give any real confirmation that you really have done phone with the same kind of damage like described in this thread it's better to be silent. Against you ? To be honest I am little bit busy to say something against somebody (and against you) but if you think that I have nothing to to but only say something against you I just want to say: I don't like people who write "this not work, only that work perfect", I prefer technical explanation instead of other products discussion in Infinity-Box support forum. So, next time make detailed technical explanation in ther case just be silent ! |
01-15-2012, 13:57 | #12 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1496038 Status: Offline Sonork: ajay Thanks Meter: 2 | avg, pandora, limewire Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... warning: wrong data size at 0x01004400, retry... warning: wrong cs at 0x01004400, retry... read error recovered warning: wrong data size at 0x01007000, retry... warning: wrong data size at 0x01007000, retry... warning: wrong cs at 0x01007000, retry... read error recovered current eeprom imei: 352691012697413 current otp imei: 352691012697413 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352691012697413_LG-KG110_20120115-182028.B1E.bin ........ version: XXX-XXV10d07KG110P40 Check flash Done Check space ... current eeprom imei: 352691012697413 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 42 sec Remove/Install battery now ! |
1112 imei change by patch credits consume but imei is still that | sairat | Universalbox | 0 | 07-14-2009 08:54 |
M620 imei dead 00000 Last vers. software | osom | UST Pro II | 3 | 05-14-2009 16:23 |
Flashed imei patch on 5140 with jaf box but when pressing *#06# imei is same?? | shahzad9 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 10-29-2005 19:20 |
