05-17-2009, 08:43 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Cann't be as I've flashed a lot of K220i with Infinity Box. May be you are not selecting the correct files for flashing. Try to flash with some other files like "K200i_K220i_main_R1AA008_CXC1250829_En_Ru[1].80M" and flex as "K220i_flex_R1AA008_CXC1250829_CDA102806-1_R4A[1].80F" or some other combination. Also always post log of flashing so that everyone can understand better and could see the problem. |
05-17-2009, 09:56 | #4 (permalink) |
Freak Poster Join Date: May 2009
Member: 1028430 Status: Offline Thanks Meter: 65 | COM6 [VCP0] selected module v1.32 Device: Sony-Ericsson-K220i "advanced chip detection" active Action: flash write "smart write" active "format ffs" active Write: Firmware Write: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AB003 software version: CXC1250814 version flex: CDA102806/1 imei: 35619701270349 Check hardware done Read data ... Read data done Check data ... Check data done Write ... Area: Firmware flash: 01227E22212200:92EA0000000000 Write: Firmware flash: 01227E22212200:92EA0000000000 Write: Firmware flash: 01227E22212200:FFFFFF00000000 Write: Firmware Area: Flex flash: 01227E22212200:FFFFFF00000000 Write: Flex flash: 01227E22212200:FFFFFF00000000 Erase: ffs ffs format done Write done Finished, time used: 384 sec Remove/Install battery now ! i flash , but the phone does not power on, before it only camera not save problem |
05-17-2009, 10:40 | #6 (permalink) |
Member: 1028430 Status: Offline Thanks Meter: 65 | COM6 [VCP0] selected module v1.32 Device: Sony-Ericsson-K220i "advanced chip detection" active Action: flash write "smart write" active "format ffs" active Write: Firmware Write: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AB003 software version: CXC1250814 version flex: CDA102806/1 imei: 35619701270349 Check hardware done Read data ... Read data done Check data ... Check data done Write ... Area: Firmware flash: 01227E22212200:92EA0000000000 Write: Firmware flash: 01227E22212200:92EA0000000000 Write: Firmware flash: 01227E22212200:FFFFFF00000000 Write: Firmware Area: Flex flash: 01227E22212200:FFFFFF00000000 Write: Flex flash: 01227E22212200:FFFFFF00000000 Erase: ffs ffs format done Write done Finished, time used: 384 sec Remove/Install battery now ! all is ok now by writing erom, thanx for support |
K220 write eeprom problem help | tahod | Infinity-Box | 13 | 04-01-2010 11:21 |
k220 unsupported accessory | umarmsn | Sony Ericsson | 0 | 03-29-2010 15:57 |
k220 error help for soluction | speed infotech | SETool2 | 0 | 03-14-2010 11:01 |
k220 go to contact then cell will restart help plzzzzzzzzzzzzzzzzzzzzzzz | pankaj_alfa | Sony Ericsson | 4 | 06-05-2008 15:20 |
@SoftMobile help k200-k220 | notgood | MT-BOX | 1 | 02-28-2008 09:17 |
