05-22-2009, 08:11 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | nothing wrong with software see log ==== log: [5/21/2009 1:34:10 PM] ==== COM4 [VCP0] selected module v1.32 Device: Sony-Ericsson-K220i "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Write: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 406250 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AD001 software version: CXC1250818 version flex: CDA102806/1 imei: 35243402169799 Check hardware done Read data ... Read data done Check data ... Check data done Write ... Area: Firmware flash: 01227E22212200:92EA0000000000 Write: Firmware flash: 01227E22212200:92EA0000000000 Write: Firmware flash: 01227E22212200:46237300000000 Write: Firmware Area: Flex flash: 01227E22212200:46237300000000 Write: Flex Write done Finished, time used: 428 sec Remove/Install battery now ! i think it should b battery problem or hardware problem |
The Following User Says Thank You to deepakgarg For This Useful Post: |
05-24-2009, 11:44 | #6 (permalink) |
No Life Poster Join Date: Feb 2005 Location: El M'Hayssar Age: 48
Member: 116657 Status: Offline Thanks Meter: 56 | it is common problem of these SE fones using infinity i think it is caused by bad quality cable connector used in infinity cable other boxes use good cable good one looks like a fat connector and this used by infinity looks to be slim this cause faulty communication with these fones ! this is fat connector this is slim one br Last edited by BENCHENA; 05-24-2009 at 11:53. |
05-24-2009, 11:53 | #7 (permalink) | |
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
05-24-2009, 14:18 | #12 (permalink) |
Member: 116657 Status: Offline Thanks Meter: 56 | good because i have tested well working fone and appear this bad communication issues as member said that below i change my slim connector by a fat one and communication is better now this message about connector it's not for u i make suggest for thread starter ipmart and gpg cable are not all good sometimes you made ur own cable and it's better than buy bad one ! @ mohit_kripalu01 try another cable with fat connector |
3110 after flash showing error in mxkey | shivashakthi | Nokia Base Band 5 ( BB-5 ) | 5 | 02-03-2010 12:00 |
3110 after flash showing error in mxkey | shivashakthi | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-03-2010 09:22 |
w810 usb flashing show error | israrbjr | SETool2 | 0 | 05-02-2009 08:49 |
u700 after flash showing error on screen | sairat | UST Pro II | 1 | 04-22-2008 13:54 |
