Old 03-06-2009, 05:15   #1 (permalink)
neetika99's Avatar
Member: 588837
k220i...inactive sim....fixed
sony k220i problem was with sim show INACTIVE SIM
action taken=formatt ffs
all ok done...working perfect.here r logs
COM1 [VCP0] selected
module v1.30
Device: Sony-Ericsson-K220i
"advanced chip detection" active
Action: reset settings
Checking data, wait...
Boot ...
Press Power button now !
loading...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 01227E22212200:92EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
software version: R1AA008
software version: CXC1250818
version flex: CDA102807/30
imei: ##############
Check hardware done
Read data ...
reading Sony-Ericsson-K220i_##############_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35619701102754_eeprom_calibration-1_20090306-103006.80E.bin
reading Sony-Ericsson-K220i_##############_eeprom_calibration-2...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_##############_eeprom_calibration-2_20090306-103015.80E.bin
Read data done
Check data ...
Check data done
Write ...
flash: 01227E22212200:46237300000000
Erase: ffs
Write done
Finished, time used: 48 sec
Remove/Install battery now !
The Following User Says Thank You to neetika99 For This Useful Post:
Old 03-06-2009, 15:34   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
module v1.30
Boot ...
loading...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
Read data done
Check data ...
Check data done
Write ...
Erase: ffs
Write done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 03-20-2009, 15:09   #3 (permalink)
murthyy's Avatar
Member: 265133
thanks neetika99 and infinity team
today i resolved the k220i INACTIVE SIM
heres is the log
COM7 [VCP0] selected
Device: Sony-Ericsson K220i
Action: reset
Boot...
loading...
Boot done
Check connection...
Set baud...
115200
Set baud done
Check hardware...
version sw: R1AA008
version sw: CXC1250818
imei: ***************
Check hardware done
Read data...
reading Sony-Ericsson K220i_**************_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson K220i_35619701128602_eeprom_calibration-1_20090320-192524.80E.bin
reading Sony-Ericsson K220i_**************_eeprom_calibration-2...
file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson K220i_35619701128602_eeprom_calibration-2_20090320-192536.80E.bin
reading Sony-Ericsson K220i_3***********_ffs...
file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson K220i_************_ffs_20090320-193141.80E.bin
Read data done
Check data...
Check data done
Writing...
Erase: ffs
Writing done
Finished, time used: 450 sec
The Following User Says Thank You to murthyy For This Useful Post:
SE K220i turning off fixed by EEPROM repair! kiwiboi Infinity-Box 2 02-07-2013 01:13
inactive sim an all sim cards after unlock gonads Seking Server 3 10-17-2008 21:15
k220i inactive sim help urgent!!!! Miftah_Lutfi Sony Ericsson 3 01-19-2008 19:04
K700i inactive sim xloaderen Cruiser Suite 7 10-03-2005 12:13
S700 inactive sim mcsqd1 Sony Ericsson 1 08-23-2005 10:20
Page generated in 1.11491 seconds with 11 queries
