03-13-2016, 15:35 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | karbon a2+ format not done Code: Operation : Check / Read Info [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008A , [HYNIX] H9DA4GH4JJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01 DEV RID : AEAB45F578D4FE9FC73E3ABB4CEAD5E0 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : telacom15_ics2 ProdModel : Karbonn A2+ Device : telacom15_ics2 AndroidVer: 4.0.4 MTKxCPU : MT6575 MTKxPRJ : ALPS.ICS2.MP.V1.36 SECURITY : IMEI_SW [1] : IMEI_SW [2] : BTMAC Addr : FFFFFFFFFFFF WiFi MAC : FFFFFFFFFFFF Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Format FileSystem [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008A , [HYNIX] H9DA4GH4JJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01 DEV RID : AEAB45F578D4FE9FC73E3ABB4CEAD5E0 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Read Flash [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008A , [HYNIX] H9DA4GH4JJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01 DEV RID : AEAB45F578D4FE9FC73E3ABB4CEAD5E0 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Too old device, FW reading not supported! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! |
03-13-2016, 15:49 | #2 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | now flash done set working ok but still cant format and still imei in software not showing ok Code: Operation : Check / Read Info [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008A , [HYNIX] H9DA4GH4JJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01 DEV RID : AEAB45F578D4FE9FC73E3ABB4CEAD5E0 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : telacom15_ics2 ProdModel : Karbonn A2+ Device : telacom15_ics2 AndroidVer: 4.0.4 MTKxCPU : MT6575 MTKxPRJ : ALPS.ICS2.MP.V1.36 SECURITY : IMEI_SW [1] : 9EA1B0E27159DBF IMEI_SW [2] : 9EA1B0E27159DBF BTMAC Addr : FFFFFFFFFFFF WiFi MAC : FFFFFFFFFFFF Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Format FileSystem [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008A , [HYNIX] H9DA4GH4JJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01 DEV RID : AEAB45F578D4FE9FC73E3ABB4CEAD5E0 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Done! Elapsed: 00:00:07 Reconnect Power/Cable! |
03-13-2016, 15:55 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Already got report about problems in old NAND phones. Will be fixed in next release. |
